Question about Maxi-Cosi Maxi-Taxi Citi Stroller
Digitax taxi meter I need to know if I can set the time and how to do it
The time on the digital x3. Is wrong by almost 30 mins I need to know if I can set it or do I need to find some one near Plymouth to help
How to change date on halda m12 taximeter
The date may change only as you cycle through the time setting in 24-hour increments. The date and time are interrelated.
Jun 05, 2014 | Humminbird Kienzle-Argo Taxi Meter 1150
I have a Digitax F2 taxi meter. The display will not set the correct tariffs and only comes up with the numbers 666666. Can you tell me how to reset, "flash" the meter. Thanks.
I just had this problem with my Digitax f2.
My car came out of the garage after 3 days.
The meter turned on, and displayed the correct date, time, and year.
I returned home \'till I went out to work at 10pm.
When I went out to work, I took my first fare, and tried to start the fare on the meter.
It showed error 666666.
As I drive a Hackney, it is illegal to work without a meter.
Consequently, I had to go home, and loose a nights work.
The next morning, I went to my local Digitax rep, and had it fixed with their Microchip Key, in a couple of minutes.
The rep told me that as the cars\' battery had been removed, and replaced, this action had disabled the meter.
The moral of this story is when you get your taxi back from a garage, make sure that your Digitax meter is working properly, by setting a fare.
Also, make sure that you pick up the car in time to get to your local Digitax rep, to get any problems fixed the same day.
Oct 04, 2011 | Sony F2 Taxi Meter
The time on my Garmin 120 gps on my boat is 30 min wrong
Seems to me like a system time zone setting adding/subtracting 30 mins based on the geo setting such as GMT / CST etc. Check for the time zone setting in the system menu.
Jun 28, 2011 | Garmin GPS
My nokia x 3 switches off eveytime, what can be wrong. shows a white screen then switches off
For this you need to flash your handset(if it is under warranty contact the service center)
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you
Don't Forget To Rate
Jan 25, 2011 | Nokia X3 Cell Phone
How to unlock nokia x302
unlock nokia x3-02
Nov 30, 2010 | Cell Phones
Entered noka x3 security code wrongly three times
if it is security code and NOT pin code then it is easy.... from the last time you tried your security code, switch off your phone for about 20 mins, then try again, BUT THIS TIME PUT THE CORRECT CODE...!!! PROBLEM SOLVED.. plz leave good feedback.. thanks...
Oct 25, 2010 | Nokia X3 Cell Phone
I need to hook up a centrodyne taxi meter to 2000 dodge caravan. I need to know how to hook it up. thanks
It's very easy on the pcm you will find a blue/orange wire. That's you hook up wire(vss). There are two set of wires off the meter bracket one comes with three wires and the other one with two. The one with 3 one goes to battery(red) ground(black) and top light(green or white). The other set of wires only the white one is connected to the vss.(vehicle speed sensor)
Sep 29, 2010 | 2000 Dodge Caravan
Nokia x3 -00 unlock code
hi i have my moible nokia x3-00 but i want to know how to get the unlocked and resisted code open??!!! so i dont know why its damn it my nokia are locked of resisted code!!! i need know when thats come released???
Aug 31, 2010 | Nokia X3 Cell Phone
Baby Gear Logo
26 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
