Question about Frigidaire GLEQ2152ES Electric Dryer
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
Dryer is drying but stops if put on any cycle over 15 min. Dryer stops with single beep and four of the five lights blink
  • Frigidaire Master
  • 5,323 Answers
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
Posted on Dec 20, 2014
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
Krazytech
  • 725 Answers
SOURCE: Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Posted on Sep 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Frigidaire FEQ1442ESO Dryer
Unplug it.
Remove the 2 screws on the back side to get the top off.
Slide the top off and take the 2 control panel screws off lift up the control panel and get he tech sheet out. Consult it to find out about them beeps. Use this LINK to access service videos for your machine.
Posted on Sep 30, 2010
SOURCE: front load dryer frigidaire model
I have the same problem... please help.
Posted on Oct 29, 2010
SOURCE: I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Posted on Jan 17, 2011
What is the appropriate fix for front load dryer that turns on and begins to run, but at any moment it stops, beeps over and over and lights all flash. The only way to stop the beeping/flashing is to
Thanks for the make and model of dryer. It is likely the thermistor is faulty. This tells the dryer how hot it is getting. If dryer is ok to start with (cold) and then starts doing strange things once it heats up, then this is what one would suspect. The control board problem would show up in strange ways including not being able to start the drying cycle. For location of thermistor see the drawing on this site. The model may not be exactly same as yours but gives an idea.
Items 33 and 36 in diagram 1. Frigidaire Washer LEQ2152EE1 Parts List
Sep 10, 2014 | Dryers
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Starts drying for about 15 mins then stops
Sounds like this is a gas dryer. Look at your burner after the dryer stops heating .Does the ignitor come on then go off without the burner firing?If so replace the 2 coils on top of gas valve wp #279834 msrp $20.00. Please rate my solution :)
Nov 14, 2009 | Dryers
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
15 year old Kenmore dryer not working
Sounds like you thru the breaker. If not, it is the door switch.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
WTV74307GB
the warning does not strictly mean filter only
there is a lint blockage somewhere in the vent system and there is only a single response the dryer knows to make
fan
fan housing
duct
outside vent
could all be sufficiently blocked to set off the warning
Oct 19, 2008 | Dryers
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Frigidaire GLEQ2152ES Electric Dryer Logo
226 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
