Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
My blue parrot has lots of background noise
Everyone says theres too much background noise
Too much noise with my beko unit (specially in the evening) is this normal??
Remember during the day time.There is a lot outside noise that drowns out the noise of refrigerator. And in the evening there's less background noise to mask it.
Apr 18, 2015 | Beko Refrigerators
Trying to pair b250 xt with samsung rugby2 lots manual
Make sure you device is in visible mode first. In power off condition of headset, press on button for 30 seconds. When blue lights starts blinking fast then search on device and add it.
Custom Car Grilles
Aug 01, 2012 | Parrot Blue B250xt Bluetooth Wireless...
Blue parrot lights blue and red keep flashing and there aren't any beeping noises
If your headset is 6 or more months old, it could be the rechargeable battery is due for replacement. The power supply or battery is the one thing that can cause all sorts of odd symptoms. I read your post and put a known bad battery into one of my 3 Blueparrott B250-xt headsets and did just as you described. If you would like to order a new battery for this headset, email me at ebhammonds@gmail.com. They are $20 and shipping is free.
Jan 02, 2012 | Radio Communications
On answering a call i can hear them but they cant hear me
I would delete all paired devices from the Parrot kit and delete the Parrot kit from your phone, then remove your battery from your phone for 5 mins, then repair as a new phone. If this does not work you have a microphone issue, check the wire is not trapped behind one of the trims.
Nov 21, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Parrot MKi9200 car phone and IPOD problem. 18 months old and worked fine until moved from bmw to golf mark 5. IPOD now not recognised (any IPOD) have done a restore factory settings without success. ...
A replacement blue box is nearly the same as a new kit. I would do a software update on the Parrot and make sure you do a reset on the ipod, back up the ipod first. I would contact a parrot certified installer if this does not cure it. Parrot web site will have a list of installers. If the kit powers up the blue box is not faulty.
Feb 21, 2011 | Parrot Mk6000 Bluetooth Hands Free Kit
My hands free parrot in my car went out in the middle of a call and has not worked since. Don't have a clue where to start top find out whats wrong
Is there anything on the display or is it a dead Parrot?. Does it make any noises?. If there is not life at all them you will need to find the main blue box behind the dashboard and check the fuses, normally behind the radio. otherwise go to parrot web site and contact one of their certified installers.
Jan 10, 2011 | Parrot CAR PAICK3300 GPS Receiver
CK 3200 LS severe background noise heard by other party - Can download software update ok and pair bluetooth laptops ok, but when I try to send download to Parrot on some computers I get message no dongle,...
get your laptop and car ready then call parrot techinical, they will talk you through it, you need to select the correct serial port. it also depends on what type of donlge you are using.
Nov 13, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Turning off Blue-Tooth and using phone
there is no another way to off your BT so you have to turn off your Bluetooth and go when u come back then turn on again its automatic connect with your car
May 15, 2017 | Parrot Cell Phones
A lot of background noise when playing back.
The pic looks like a TRC5880? If thats the case they are naturally quite noisey. The motors vibrate too much in my opinion. Theres not much you can do with it unfortunately. Suggest a new recorder or get that one repaired.
Nov 07, 2006 | Sanyo TRC-5830 Handheld Cassette Voice...
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
18 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
