Question about RTO Basement Watchdog Sump Pump
Where to find manual for battery watchdog model #30-HDC1405
How to reset after power outage
Your Digital Watchdog dw-vf162t should be reset according to proper instruccions. If you don't have the manual, you shshould contacte provider
Contacts Digital Watchdog
May 14, 2015 | Digital Watchdog dw-vf162t, vmax-flex 16...
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Apr 26, 2014 | Zanussi Freezers
How to factory reset a digital watchdog dvr
how to reset password Digital Watchdog DVR MODEL DW-VMAX480-8
Mar 15, 2013 | Home Security
Lights remain red, battery 0%,and message is "pic watchdog emergency". What is wrong
OK, I found the problem. The ribbon cable to the sonar board from the motherboard was out just a fraction of an inch. Aslight nudge moved it in just a little, but enough I guess, it works now.
Dec 15, 2012 | Parrot AR.Drone 2.0
System reset by watchdog.tion
I've never seen a watchdog.tion error but watchdog errors can be set up on some CMOS when the 5v power from the power supply is bad.
I can't find anything on your specific error tho but I would try a different Power Supply Unit.
Jul 31, 2012 | Biostar 945GC-M7 TE Motherboard - v6.0,...
My backup battery for my sump pump is telling me to recharge the battery. These things are all new to me never had to have one. My model is ace in a hole A5000. Have no manual from the previous owner....
yes but it has to be disconnected before you charge it. also check the battery for water level in all cells. basement watchdog is a better unit. yours on a good battery might run for 4 hours when the powers out. it should have a large deep cycle battery for it to work well
Nov 22, 2017 | Simer 3/4 Hp Stainless Steel Sump Pump
Redout on jacuzzi spa model j340 has --- code.has been working
The condition you see on the topside control is known as "watchdog" Which usually means that the spa thinks it's "overheating"
Turn off the power to the spa for a couple of minutes, then restart, Watch the topside control if the temp. starts to climb & read a lot hotter than the actual water temp. Then it goes into watchdog, most likely you have a bad temp sensor. In some cases just resetting the spa will clear the watchdog & everything works fine. (Voltage fluctuations, "spikes" can freak out the electronics & the tub goes into watchdog to protect itself) If the spa immediately goes into watchdog when you reset it, you might have a bad board. (Let's pray it's not) 90% of the time it's a bad temp. sensor.
Jan 12, 2009 | Home
Ultra10 3750115 Motherboard displays watchdog reset intermittently
Try this
replace M/board battery or rest BIOS to default and try again
Oct 21, 2008 | Computers & Internet
RTO Basement Watchdog  Sump Pump Logo
61 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
