Question about Home Security
What is the value of a Remington Rand Safe,
Ledger Tray, serial no. 232487
2 Suggested Answers
twoy1y1z2
  • 5 Answers
SOURCE: what is the value of a Remington Speedmaster 552
In nice condition the first year production in 1957 goes for about $450. Newer ones in the 1980's and newer are going for $350 to $400.
Posted on Apr 25, 2014
Ledger wrong posted to balance sheet
Delete testing account and check again
Dec 18, 2013 | Auto Count AutoCount Accounting
I am still trying to scan 11x17 and I sent it up in control center but still not working right it scans 8.5x11
CHANGE CONTROLCENTER CONFIGURATION
1. Open ControlCenter. START -> (ALL) PROGRAMS -> BROTHER -> XXX-XXXX (Model of machine) -> CONTROLCENTER. An icon will appear in the system tray by the clock. You may have to click this icon to launch the program.
2. Click CONFIGURATION -> SCAN -> FILE (or any other scanning option youare using)
3. Under Software Button, change Document Size to LEDGER 11 x 17 in.
4. Under Device Button, change Document Size to LEDGER 11 x 17 in.
5. Click OK
6. Place document on the Brother machine.
7. To initiate the scan, left click on FILE (or any other scanning option you selected in step 1). This issue should now be resolved.
May 18, 2011 | Brother MFC 6490CW InkJet Printer
Panasonic dp 6030 copier error code e02-10
E2-01 sounds like a tray 1 lift malfunction. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, This usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes, the paper can fall back causing the gears to break. We normally replace the whole lift motor assembly.
If there is more then one paper tray, you can pull tray 1 out, (the code should not appear with tray 1 open. You can at least use the manual feed to keep them going until you can get the part.
May 05, 2011 | Panasonic Office Equipment & Supplies
How to copy ledger size to ledger size - overriding the letter size in brackets. Can't find a manual anywhere
yep!
depending on the setting of your machine.
if your machine is set to us standard, there you will be able to see ledger size paper selection
but if your machine is set to jp/eu (default) you can only copy with a3 size as the biggest size
that's it
May 21, 2010 | Panasonic DP-8016P Copier
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Panasonic FP-7735 won't recognize paper tray
Can you hear the tray rise when you close it? Is there a red, blinking "out of paper" light on the control panel? Can you select the tray manually?
Or, you had a power outtage, or gremlins, and the settings reset itself, you can go in to service mode and set the trays up again.
Hold the following keys to fire up Function mode. "Function + Original Size + 3". Hit 5 for F5 mode. F5-14 is tray 1. If you have a duplex(ADU) unit installed, you'll want to check out tray 2. F5-14 is tray 1, F5-15 is tray 2 all the way down to F5-18.
Key in whichever number you need.
0: none (no tray installed)
1: Ledger
2: Legal
3: Letter
4: Letter-R (landscape)
5: Invoice
Jan 24, 2008 | Panasonic FP-7735 Black and White Copier
Won't print ledger size
Are you loading the ledger in the right place main tray or by pass?
Printer properties set correctly?
Oct 10, 2007 | Minolta PageWorks 20 Laser Printer
Home Security Logo
352 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
