The cooling system of a chevy 6 cylinder 250 cubic inch displacement engine has a capacity of 3 1/2 gallons. if a solution of 3/8 ethylene glycol (the rest is water) is used to protect the engine against freezing temperatures, how many quarts of ethylene glycol are used?
  • 29 Answers
SOURCE: 1990 dodge dakota cooling system capacity???
at the max two gal, mix 50/50
Posted on Oct 01, 2009
  • 2309 Answers
SOURCE: Drain Engine Coolant in 2005 Chevy Silverado 2500 HD
there is a petcock at the bottom of the rad drain ti from there and use a antifreeze tester to check protection temp
Posted on Nov 18, 2009
ZJLimited
  • 17970 Answers
SOURCE: firing order for 1966 ford mustang 200 cubic inch
The engine is a 200 CID straight six, the firing order is 153624...
Just pop the distributor cap and have someone crank the engine while you watch the rotor.
How I can determine which hole in the distributor is assigned to the #1 plug wire.
Pull the number one plug. Turn the engine over slowly (with a wrench) while holding your finger over the plug hole. When the air builds (a lot of) pressure you are coming up to the number one spot on the distributor. (the rotor will point to the location of the #1 hole in the distributor.)
Quick methods to disable the engine I have seen people do on the classics:
Close the points by loosening the set screw
Pull the rotor cap
Connect a wire from the coil to ground. (effectively closes the points. Can damage the coil if key is left on.)
Pull the main ignition wire
And there are some tricks at the starter solonoid involving the ballast resistor bypass that is used to provide a hotter spark while cranking. (Two little wires at the starter solonoid - one is crank the other is the ballast bypass.)
Might give those a look-see. Best of luck (rememeber rated this help).
Posted on May 17, 2010
Testimonial: "This has been very helpful!! Thank you!"
ZJLimited
  • 17970 Answers
SOURCE: 2006 Chevy Uplander LS coolant capacity?
Cooling SystemTotal Cooling System Capacity (qts) : 12.15
Source: chevrolet-uplander-4dr-ext-wb-fwd-ls
Posted on Aug 24, 2012
What is the engine displacement of chevrolet nova 4 cylinder 1962
The 1962 Chevy Nova 4cyl was the 153-cubic-inch (2.5 L) inline engine.
It had a bore of 3.875 inches (98.4 mm) and a stroke of 3.25 inches (82.6 mm). The firing order is 1-3-4-2
Feb 24, 2018 | Chevrolet Cars & Trucks
What is the cubic capacity of ge dryer dclr333et1aa?
Not sure of your question. Picture and heading describe a Freezer/Refrigerator and your question regards a dryer.
Any way, to get cubic capacity, get out your trusty yard stick or tape measure and get the inside dimensions of your unit. If you take length x width x height you will get the cubic size. If it is a dryer with a round inside it is a bit more involved. In this case measure the diameter of the inside and the depth. The take the diameter and square it, [ recall your high school math ie area of a circle??] and multiply the answer times the depth of the inside. If you measure everything in inches the result you get will be cubic inches. The great Chevy V-8 engines in my day , 1960"s muscle cars had as much a 400 cubic inches displacement.. ahh those were the days
Apr 04, 2014 | GE (GTS16BCS) Top Freezer Refrigerator
Hi guys, my bike keeps cutting out if i put lights on or press the brakes front or rear. bike starts and idles fine. totally stumped and any help would be great
  1. Yamaha Fazer Engine and Transmission
    • The 1998 Fazer is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with displacement measuring 36.55-cubic inches. This motor generates 95 horsepower at 11,500 rpm and 45.0 foot-pounds of torque at 9,500 rpm. It has a six-speed transmission and a liquid cooling system. The 1998 Fazer has a top speed of 139.8 mph.
    Yamaha Fazer Brakes, Weight and Fuel Capacity
    • The 1998 Fazer has dual-disc front brakes and single-disc rear brakes. It has a seat height of 31.1 inches at its lowest setting and a dry weight totaling 416.7 lbs. The Fazer has and electric starter and a fuel capacity of 4.75 gallons.
    Yamaha Thundercat Engine and Transmission
    • The 1998 Thundercat is powered by a four-stroke, 16-valve, in-line, four-cylinder engine with a displacement of 36.55-cubic inches. It generates 100.00 horsepower at 11,500 rpm and 48.7 foot-pounds of torque at 9,500 rpm. The Thundercat has a six-speed transmission and a liquid cooling system.
    Yamaha Thundercat Brakes, Weight and Capacity
    • The Thundercat has dual-disc front brakes and single-disc rear brakes. It has a dry weight of 412.3 lbs. and a seat height of 31.3 inches at its lowest setting. The 1998 Thundercat has an electric starter, a 5.0-gallon fuel capacity and a top speed of 158.4 mph.
Jan 14, 2013 | 2003 Yamaha FZS 600 Fazer
I have a yzf 426 yamaha. What fuel do I put in it? What oil do I put in it? Is it a 4 stroke motor bike? Please help me - Thankyou!
Model: Yamaha YZ 426 F Year: 2002 Category: Cross / motocross Rating: 71.6 out of 100 Engine and transmission Displacement: 426.00 ccm (25.99 cubic inches) Engine type: Single cylinder, four-stroke Compression: 12.5:1 Bore x stroke: 95.0 x 60.1 mm (3.7 x 2.4 inches) Valves per cylinder: 5 Fuel control: DOHC Cooling system: Liquid Chassis, suspension, brakes and wheels Front suspensiontravel: 300 mm (11.8 inches) Rear suspension travel: 315 mm (12.4 inches) Front tyre dimensions: 80/100-21 Rear tyre dimensions: 110/90-19 Front brakes: Single disc Front brakes diameter: 250 mm (9.8 inches) Rear brakes: Single disc Rear brakes diameter: 240 mm (9.4 inches) Physical measures and capacities Dry weight: 105.0 kg (231.5 pounds) Seat height: 998 mm (39.3 inches) If adjustable, lowest setting. Overall height: 1,303 mm (51.3 inches) Overall length: 2,171 mm (85.5 inches) Overall width: 827 mm (32.6 inches) Ground clearance: 375 mm (14.8 inches) Wheelbase: 1,490 mm (58.7 inches)
May 02, 2011 | 2002 Yamaha YZ 426 F
Excuse me i have a suzuki savage 650 1987 and y want to know what is the timinng for this motorcycle, please help me .... thanks
here are some specifications i hope they help you
Manufacturer (Make) Suzuki Model Name LS 650 Savage Year 1986 Category(class) Cruiser / Chopper / Custom Engine Engine Capacity (Displacement) 652 ccm (39.79 cubic inches) Engine Type 1 cylinder Bore x Stroke ?94.0 mm x 94.0 mm (?3.7 inches x 3.7 inches) Bore/Stroke Ratio 1 Stroke 4 Valves per Cylinder 4 Timing System OHC Cooling System Air Powertrain Gearbox 4 speed Chassis/Suspension/Brakes Front Brakes Single disc Rear Brakes Drum Front Tire 100/90-19 Rear Tire 140/80-15 Dimensions Curb Weight 171 kg (377 lb) Fuel Capacity 11 litres (2.91 gallons) Performance Max Power 27.00 HP (19.7 kW) at 5200 RPM Power/Weight Ratio 0.16 Hp/Kg Top Speed 127 km/h (79mph) Acceleration (dart, speedup) time
0-100 km/h 9.2 seconds 0-60 mph 8.7 seconds
  • 1/4 mile
  • 60 to 140 km/h, highest gear
    also heres a link of a almost complete tare down and rebuild
    http://www.motorcycleforum.com/showthread.php?t=102346
    Mar 25, 2011 | 1986 Suzuki LS 650 Savage
    Actually i dont want any solutions;i just want to know about yamaha rd 350
    Model: Yamaha RD 350 Year: 1986 Category: Classic Rating: 76.9 out of 100. Show full rating and compare with other bikes Engine and transmission Displacement: 347.00 ccm (21.17 cubic inches) Engine type: Twin, two-stroke Power: 63.00 HP (46.0 kW)) @ 9000 RPM Top speed: 190.0 km/h (118.1 mph) Compression: 6.0:1 Bore x stroke: 64.0 x 54.0 mm (2.5 x 2.1 inches) Fuel control: Membrane & power valve Cooling system: Liquid Gearbox: 6-speed Transmission type,
    final drive:
    Chain Chassis, suspension, brakes and wheels Front tyre dimensions: 190/90-18 Rear tyre dimensions: 110/80-18 Front brakes: Dual disc Rear brakes: Single disc Physical measures and capacities Weight incl. oil, gas, etc: 170.0 kg (374.8 pounds) Fuel capacity: 20.00 litres (5.28 gallons) Other specifications Further information Parts and accessories Our partner CMSNL ships low cost OEM motorcycle partsimage-1696787-10826297 to Australia, Austria, Bahamas, Belgium, Canada, China, Croatia, Cyprus, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hong Kong, Hungary, Iceland, India, Ireland, Italy, Japan, Kuwait, Latvia, Lithuania, Luxembourg, Macedonia, Malta, Montenegro, The Netherlands, New Zealand, Norway, Poland, Portugal, Serbia, Slovakia, Slovenia, South Africa, Spain, Sweden, Switzerland, Taiwan, Ukraine, United Kingdom, The United States and more. Or check out parts and accessories from our other partners.
    Dec 29, 2010 | 1986 Yamaha RD 350
    Is there special directions to put coolant in?
    Welcome to FIxYa.com
    How to Fill Coolant
    If the coolant system has been flushed, first add 100 percent ethylene glycol in
    the amount listed for the appropriate engine application. Then slowly add clean
    water to the system until the level of the coolant mixture has reached the base-of
    the radiator neck. Wait for two minutes and recheck the level of the coolant
    mixture. add clean water if necessary to restore the coolant mixture level to the
    base of the radiator neck
    When refilling the engine cooling system, add three engine coolant supplement
    sealant pellets, GM RN 3634621 or equivalent, and GM approved new Ethylene
    Glycol Coolant DEX-COOL GM RN 9985809.
    If the cooling system is being refilled ONLY (no flush), a 50 percent ethylene
    glycol and 50 percent clean water mixture should be used to fill the system. Fill
    the system until the level of the 50150 mixture has reached the base of the radiator
    neck. Wait two minutes and recheck the level of the coolant mixture. add a 50/50
    ethylene glycol water mixture as necessary to restore the coolant mixture level to
    the base of the radiator neck.
    Install the radiator cap making certain the arrows line up with the overflow tube.
    Close all air bleeds. DO NOT over torque the air bleed valve. The air bleed valve is
    made out of brass.
    Fill the coolant reservoir with a 50 percent ethylene glycol and a 50 percent clean
    water coolant mixture. The proper amount of this mixture to be installed into the
    coolant reservoir is listed below:
    Add 0.65 liters (0.68 quarts) of a 5010 mixture of ethylene glycol and clean water
    to the coolant recovery reservoir.
    CAUTION: The low coolant indicator lamp may come on after this procedure. After
    operating the vehicle so that the engine heats up and cools down three times. if at
    any time the "TEMP' warning indicator comes on. Immediate action is required.
    Air bleed vent is at the thermostat house
    Thank you for using FixYa.com
    Regards, Lee Davidian
    Nov 09, 2010 | 1997 Pontiac Grand Prix
    2001 cbr f-y is it carb or injaction
    Model: Honda CBR 600 F4 Year: 2000 Category: Sport Engine and transmission Displacement: 599.00 ccm (36.55 cubic inches) Engine type: 599cc, liquid-cooled, inline, four-cylinder, DOHC, four valves per cylinder Stroke: 4 Bore x Stroke: 67mm X 42.5mm Carburetion: Four 36.5 mm slanted flat-side CV Compression Ratio: 12.0:1 Power: 110.00 HP (80.3 kW)) @ 12500 RPM Torque: 68.00 Nm (6.9 kgf-m or 50.2 ft.lbs) @ 10500 RPM Starter: Electric (Digital transistorized, with 3D mapping) Cooling system: Liquid Gearbox: 6-speed Transmission type
    final drive:
    #525 O-ring sealed chain Physical measures Dry weight: 170.0 kg (374.8 pounds) Seat height: 810 mm (31.9 inches) Wheelbase: 1,395 mm (54.9 inches) Chassis and dimensions Front brakes: 296mm dual disc with four-piston calipers Rear brakes: 220mm single disc Tires Front tires: 120/70 ZR-17 radial Rear tires: 180/55-ZR-17 radial Speed and acceleration Quarter Mile Time: 11.00 seconds @ 124.65mph (199.44km/h) Top speed: 260.0 km/h (161.6 mph) Power/weight ratio: 0.6471 HP/kg Other specifications Fuel capacity: 18.00 litres (4.76 gallons) including 0.8 gal. Reserve Color options: Blue/red, black/yellow, black/dark gray
    Apr 06, 2010 | 2000 Honda CBR 600 F(4)Y
    Coolant type and capacity of 2003 Chrysler T&C
    any ethylene glycol antifreeze will do regardless of colour ,50% soloution ,unless your in a zone where temperatures can drop below -20c then use neat ethylene glycol 100% if vehicle if left outside with no pre heater in the cooling system
    Jul 27, 2009 | 2003 Chrysler Town & Country
    Computers & Internet Logo
    20 people viewed this question
    David Payne
    David Payne
