Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
How do i turn off the ice maker? - GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I turned the ice maker off now I can't get it to turn on and work it freezes cubes but won't dump them in ice been
Ice maker harvest cycle is not working. Jammed timer in Ice maker unit.
Remove the wire harness of the ice maker and put it back after 5 minutes. See next day whether it is working.
If not still working. You did the right needed thing at the wrong time to shut off the ice maker. You will have to replace the ice maker.
Ice maker units are very sensitive units. Sorry to say.
Oct 23, 2017 | Refrigerators
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
    How to Repair a Refrigerator Ice Maker ' HomeTips
    www.hometips.com/repair-fix/freezer-ice-maker.html
    If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
    Jan 01, 2016 | Samsung Refrigerators
    My motor runs but doesn't turn the ice cream container. This is before I put in any ice or salt. It starts to turn then stops.
    The gears are bad inside the gearbox...
    Hereis a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    Apr 01, 2011 | White Mountain F69206X 6 Quart Ice Cream...
    Ice maker is not working.
    Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
    Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
    Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
    Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    Mar 30, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
    Ice maker not making ice. do have water, no ice
    The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    The ice maker has completely stopped producing ice
    The ice maker is producing ice poorly
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Aug 29, 2009 | Kenmore Refrigerators
    Ice maker won't quit dispensing ice cubes don't have ice skates!
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repair
    Dec 11, 2008 | Amana Refrigerators
    Ice maker not making ice refrig.model#gsc23kswc ss
    Check the following suggestions from repairclinic:
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
    Oct 10, 2008 | GE Refrigerators
    GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
    16 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
