Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
Why does tig welder start fine then gets too hot?
2 Suggested Answers
keemo68
  • 1263 Answers
SOURCE: miller Syncrowave 250 / no tig arc start
seems that you have a ground issue. make sure the ground clap is on barte metela and secured tight. make sure your tungsten electrod is about 1/8 of an inch form the edge of the cone. you will find that you will get a faster arc this way.
Posted on Apr 19, 2009
Voltage and breaker sizerequired
Can you please tell me
I am workshop Officer I brought my 250dx from USA Miller tig welding 250 Dx Solve problems Exit Fine of plant in the Pl detail gauid
Mar 27, 2014 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Have a CT-200 Hobart Welder Getting high frequency but no current?
Sounds like the problem could be with your tig torch. Inside the tig torch you have a copper cable which carries your main welding current. If there is a break in the copper the high frequency is of such a high tension voltage that it can jump across the break in cable making it appear that your tig torch is fine. If you have a multimeter check continuity from one end of the torch to the other or try another tig torch.
Nov 06, 2011 | Hobart Handler 140 Mig Welder
Tig will work normally on aluminum for a few minutes then will cut out and the only way to start it again is to scratch start it but then it will only work for a little while
this seems to be a duty cycle of the type of welder you may have,the other thing im thinking you need to be in continious cycle mode ,theere should be a switch allowing continious cycle also the main switch should be on ac mode for welding aluminum. the tungsten should be 1% with a green paint on the end .you mention you have to scratch to restart the welder you have might need a high frequency box of its own that also hooks to the welding machine, small amp welders have small duty cycle which means it will shut down if its getting over worked or hot good luck
Jul 31, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Giant inverter tig mma111 230 volt
check if the load on it is not more than its capacity and check the batteries if they are still in good condition
Nov 16, 2009 | Inverter 220 Volt Tig Arc Welder
Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Oct 20, 2009 | Welding Tools
Miller Syncrowave 250 / no tig arc start
Apr 10, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My miller dx250 keeps blowing a water line. what could be causing this?
if has good water flow, check that cooler coils are clean, make sure hot and cold connections are correct
Jan 02, 2009 | Miller Electric Manufacturing Electric...
TIG welder tips
Go to your local welding supply store. A TIG welder is a specialized welder that cannot be found at a building supply store. Stores like Maine Oxy-Acetylene Supply or Grainger Industrial Supply will carry them. Look in the classifieds of publications like Uncle Henry's. There you might find a TIG welder that someone is selling—and it may be at a good price. Be sure to ask the owner questions and take a look at the TIG welder before buying it. Explore eBay. Yes, even eBay has TIG welders. You'll need to ask the buyer questions about the welder's history and more. Perhaps, if the seller is near enough, you might be able to pick up the TIG welder yourself and save on shipping. Visit online retailers. Retailers like Welders Direct or Welding Mart carry TIG welders and would be able to answer any questions you might have (see Resources below). Consider the manufacturer of the TIG welders themselves. Lincoln, Miller, Hobart and others have their own websites. Call the companies directly and ask a lot of questions. These vendors are the best product source for welders (see Resources below).
Aug 27, 2008 | Miller COOLMATE 3 115V TIG TORCH WATER...
Tig welder suppot
Make sure the area around your welding surface is completely clear. This will prevent fires from starting.
Aug 27, 2008 | Campbell Hausfeld WT610000AV Tig Welder...
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
79 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
