Question about Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel
I have a Maytag Gemini Double oven, model # MER6770ACW. I just had the control panel and both sensors replaced. Oven still doesn't work. It burns the outside and the inside is uncooked. In the case of muffins, rolls, baked goods..the insides are doughy. A repairman has been here 3 times and I've spent over $700 fixing this one. I'm told I am picky and to lower my oven temp for any cooking. Is there any hope for my oven?
  • 3 Answers
SOURCE: maytag double oven model #
still i have the with oven heats up and stops working the codes coming on the panel are f 1-1 and f 1-3 range model # is maytag double oven mer6770acw
Posted on Sep 13, 2008
  • 409 Answers
SOURCE: Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Posted on Sep 26, 2008
garing
  • 998 Answers
SOURCE: lower element of top oven does not heat on Maytag Gemini
replace the control
Posted on Aug 06, 2009
  • 969 Answers
SOURCE: I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Posted on Nov 12, 2009
SOURCE: maytag gemini MER6769BAW
I have this same problem now. I will be attempting to replace just the relay by unsoldering thoe old one and resoldering a new one. I eill let you know how it goes
Posted on Jan 13, 2010
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Problem with my maytag gemini double oven
You have an oven sensor shorted or poor contact at the EOC,(electronic oven control).
Jan 27, 2010 | Ovens
Maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Sep 18, 2009 | Maytag MER6772 Gemini Electric Kitchen...
hi there,
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag double oven model # mer6770acw code f1-1 and f3-1 appears on the panel when using the ovens ofcourse when it gets warm or hot the ovens stop working.thanks for help
Sep 09, 2008 | Maytag Kitchen Ranges
Maytag Gemini Electric Kitchen Range
Codes are correct .The back needs to be removed and your sensor is a 2 wire part ,The easiest way to make sure you change the right one is by turning oven to on and run a voltage test at each end of the thermostat.Rule follows : If oven is on you should have 115 -120 volts present and make sure you have the same at the other end of thermostat ,if you have the volts at one side and not the other than that is the bad thermostat. Please rate this !
Aug 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
I have maytag range model mer6770acw it give me codes f1-1 and f3-1 after 10 to 15 minths of using the oven what is that codes means and what i should do before calling the service tech. thanks
F1-1 : this indicate runaway cook upper oven.
Solution is to check oven temperature sensor,replace if necessary.
F3-1:It indicate oven temperature sensor, upper oven. You need to replace your temperature sensor.
If you need the part # let me know.
Jul 26, 2008 | Maytag Kitchen Ranges
Maytag Gemini 30" Self-Cleaning Freestanding Electric Double Oven Range - Stainless-Steel Logo
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
