Question about Polaroid Televison & Video
Very loud Buzz and screen looks like its cracked everywhere but isn't
Remote won't function. When It does this I have to unplug it before I go deaf. If i wait a little, I can plug it in and it will work until it happens again. Caps?? if so where?? or which board would be bad. Thanks, Bob now it won't turn on.. light stays red. All caps look good. Don't see anything burnt or damaged inside except the contacts of the plug going into the startup board look a little black
    Sergeant:
    Habit-Forming:
  • 194 Answers
Sounds like the t-con board
Posted on Aug 01, 2017
SOURCE: Powering up and warmup problems
why does my lcd monitor change different colors no picture just turns to all sort of colors ViewSonic N2751W 27 in. LCD Television thanks 4 your help
Posted on Jan 04, 2008
  • 230 Answers
SOURCE: polaroid tlx-03210b lcd tv tv will not turn on
Yes I think that would be the problem, aswell as some dry (cracked solder joints). A bad cap is usually bulged on the top and looks like this:
http://www.auroracomputer.ca/images/bad_cap.jpg
hope this is helpful!
Posted on May 07, 2009
SOURCE: black screen
There is a post by Stivo on this board that has helped many fix this type of problem. There are two capacitors on the power supply board that go bad and if replaced can fix this problem . The parts can be purchased at your local Radio Shack for about five dollars or less. I just did it today and it worked!!!
Posted on May 24, 2010
techman007
  • 1112 Answers
SOURCE: please can you help me narrow down an issue with
Hi:
This problem is direct and simple, Replace the T-Con board.
Posted on Nov 01, 2011
dduncan774
  • 760 Answers
SOURCE: LG 32LH30 screen won't power up. Red light at bottom glows hi to low, but no picture. Unplugged and waited overnight, plugged in again, still no picture.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
Posted on Apr 10, 2012
No sound from the left channel of my technics sl-b35 turntable
First of all remove the wires to the cartridge. With the amp on, touch each of the wires to the cartridge with your finger. one at a time. On one you should hear a loud buzz on the left and on another a loud buzz on the right.
If you get no loud buzz on the left. There is something wrong with either the connections between the deck, or the pre-amp of the amplifier. This will not effect any other function on the amp such as tape or cd.
If you do get a loud buzz on the left, check the cartridge connection or replace the cartridge.
Apr 07, 2017 | Technics Audio Players & Recorders
Polaroid TV TLA04011C very loud Buzz and screen looks like its cracked everywhere but isn't
It says in the heading that the screen looks cracked. If plsma screen is cracked it will buzz and or shuts because the panel is shorted. Look for capacitors with domed tops. Likely on the power brd. Replace them they are shorted. They will take out regulator if not replaced.
May 08, 2014 | Televison & Video
How do you turn off the deaf writting at the bottom of the screen 0f a dynes tv?
Is there any button on its remote control, marked as "CC". If so, press it once. If it is the TVs' original remote control, there it will have. No universal remote control will go.
Dec 01, 2013 | Dynex Televison & Video
VIZIO GV42LFHDTV10A loud tone/buzz frozen function
I bought the same TV for my Mother last Christmas. She is having the very same problem. If you have come up with a solution, please let me know.
Feb 03, 2010 | Vizio GV42L 42 in. LCD Television
Nothing but loud buzzing coming over the amp when trying to play. Any suggestions?
If the buzz disappears when you unplug the cable from the amp. check your cable.
If the buzz disappears when you unplug the cable from the instrument, there's something thay may have come loose inside the instrument.
If you unplug the cable from the amp., and the buzz persists, you'll have to have a competent tech. check your amp.
Apr 14, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Hitachi c2114t loud buzz on bright screen
sounds like you have a gun or picture tube shorting. check the bottom of the tubes when you turn it on and see it one of them is lit up more then the other two if you find that then unplug the circut board thats pluged into the tube and turn on the tv again and see if you problem goes away minus that color.
Feb 23, 2008 | Televison & Video
Dec 05, 2007 | ViewSonic N2751W 27 in. LCD Television
Televison & Video Logo
29 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
