Question about Home
Parts diagrams looking for a spring that holds the bled in place
3 Suggested Answers
SOURCE: Need parts diagram of Mr. Coffee CG12 filter basket assembly
I found the missing vinyl washer.
Posted on Oct 03, 2009
RonPark
  • 855 Answers
SOURCE: i need a diagram of a 1969 vw handbrake lever
You have to loosen the parking brake cables so you can pull the handle up as far as it will go. You may have to take the cables off the handle. When you do this if you look down from the front towards the pivot of the handle you'll see a small lever that can be turned, it has teeth on one end a like a flat ball on the other. Slide down the rod and use a screw driver to spin plate around so the flat ball end goes into the hook of the rod. So as you press the button it will move and unlock from the teeth on the gear that stays in place. Reattach your parking brake cables and adjust and the job will be done.
Posted on Oct 10, 2009
Testimonial: "Such a simple fix but some times the obvious is not so obvious "
How do i fix my jenn-air refrigerator JSD2488DEB .The damper door and spring fell off while removing a part.I have no idea where the spring is placed?
Parts for Jenn Air JSD2488DEB Shelves Accessories Parts
This might help. However you could try putting the damper door in without the spring and moving it through its open and closing to see what is near the door the spring could hook to. Look for small holes or tabs.
Dec 31, 2014 | Jenn-Air Refrigerators
The spring that holds up the saw came out of place along with a metal rod and a metal cap of some sort and I CANT FIGURE UP HOW TO PUT IT BACK TOGETHER..
I found this diagram online, as I only have access to the full Makita (UK) tech data at work. The spring, pin and dish look like they sit on the rear part of the table/base and go up inside the back part of the guard housing. I can't really tell from this diagram how it is all fixed in place, but you should be able to see how and where it goes together, and hopefully be able to suss it out from there.
Oct 26, 2013 | Makita 10" Miter Saw LS1030N
Car Door Diagram
Check that the spring on the notched plate is not broken and fallen out.. It may be possible to get a new spring and place it back in It may be difficult to do but with some thought it can be done.
May 25, 2013 | 1998 Holden VT Commodore
2000 dodge durango and the copper color spring fell out and cant find where it came from and also cant find a diagram on net to figure it out
Tehre are screws missing as well. The spring is what is holds the locking mechanism in the open position. This is sold as a unit, so I doubt you will be able to find a diagram that goes that granular. If I remember this setup right, youo should see a place the spring fits into, and it then pushes against the backing place (part that extends downward to puch against). Hope that helps..
Dec 23, 2012 | Cars & Trucks
The trunk spring rod on my 2005 toyota avalon has popped out. How do I replace?
you can go to the dealer and look at a diagram for the truk area one of the metal flange is bent that holds the tension rod in place just bend back straight i had same problem on my 2006 avalon
Jan 08, 2012 | 2005 Toyota Avalon
Frt brakes, the 2-v springs.... how do u get the pads and springs in place? procedure or steps, diagram could help???
what i do is put the pads in place and install the springs with one hand while holding the pads in place with the other the while holding the pads to the rotor with one hand i work the caliper on with the other.
Oct 18, 2009 | 1996 Toyota Corolla
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Reassembling the Hitachi NR 83A2 (S) magazine
The reason that you are having trouble re-assembling the ribbon spring is that you need three hands to complete the job. As you recall the nail pusher just slips into the front of the rails. The pusher has the spring and a pin to retain the spool in place. Install the spring with the bolt hole towards leaver and slip into the front of rails. Take a small paper clip and bend a small hook to catch the ribbon spring. Hook the springs bolt hole with the paper clip and hold the spring in the approximate position for bolt as you push the assembly into rails and use latch to hold. While holding spring with paperclip, insert bolt thru rails and spring into nosepiece. Just break off the paperclip at this point and you are almost done. Some nailers have a metal support clip that you would need to have in place on bolt before installing bolt thru spring. For a breakdown of the gun go to www.toolpartsdirect.com. The other bolt for rails has a support/guide for the safety foot. Good luck and email if you have questions.
Apr 11, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Home Logo
67 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
