Question about Marantz Audio Players & Recorders
Marantz sr5007 is completely dead after lightning strike
Found no shorted diodes or transistors on power supply board,could it be the TOP258MG IC?
robotek
  • 1512 Answers
SOURCE: Kenwood basic M2 Amp Lightning strike
you can check the output transistors for short circuits with the low ohms range or diode checker . If they have failed, then it is often a good idea to replace all as much stress can be placed on an output array in this type of failure. to repair reliable, all outputs on an offending channel should be replaced.
Make sure the fuse you replaced was the same type of fuse. check markings.... T stands for sloblo... a fast blo duse may let go at turn on. The power supply may have a shorted rectifier diode in it also.
be aware however, every time a fuse of that rating blows... more damage may be occurring to the amp.
Posted on Dec 15, 2007
  • 3 Answers
SOURCE: Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Posted on Jan 30, 2008
  • 4234 Answers
SOURCE: Denon AVR-3105 Unit tries to
Look for open resistors in the same area. Also, if the transistors that you replaced are the output transistors, you should replace their compliments as well. I don't have the service manual with me at the moment, so I'm juist giving you generalities. If you can, lift the center pin of the output transistors and measure (and post) the voltage readings on each of three pads for each transistor. That should give me enough info to guide you further.
Thanks,
Dan
Posted on Oct 07, 2008
SOURCE: sansui amp au11000
Check for open resitors (All Values)..also make sure that any diode stacks (Varistors) are not open or shorted....mostly make sure you have replaced the BIAS POT! Lastly U could check for open traces and bad solder joints..also look for tiny solder bridges under an eyeloop magnifier on foil side of PCB>especially after replacing multiple components.
Eric
Posted on Jan 16, 2009
landsend
  • 1066 Answers
SOURCE: possible burnt out power supply on Yamaha RX-V557
Can you check the power transformer, voltage & resistance.
You may have to unsolder some components to test them...such as the rectifying diodes and the transformer.  I believe that the outputs from the power supply board are all DC voltages.  Is there all so a IC chip on the power supply board?  Does your insurance cover lightening damage?
Posted on Mar 25, 2009
Sanyo AVM-3651G fuse box?
Should be on the board near where the power cord connects. It should be a fuse with pigtails that is soldered to the board. If you had a true lightning strike then the power diodes are probably shot ad well and more than likely the power transistor.
Aug 16, 2016 | Sanyo Televison & Video
Marantz sr5007 power supply dead
Have you tried a protection reset on the unit ?
Jun 22, 2014 | Marantz Audio Players & Recorders
Marantz sr5007 receiver dead after lightning strike
Hi Ridgep.
Replacement of the TOP258MG IC Should resolve your problem. Make sure you have fully discharged all the caps on the primary side of the power supply before fitting your replacement IC as they are very easily destroyed during installation.
May 08, 2014 | Marantz SR5007
Xtronie x20qa12074802 colour television burns fuses when i power it
that was mean has bad major component either in the power supply board or in the main board.check first shorted bridge type diode and regulator ic and FET transistor in the power supply board if getting shorted.
Sep 07, 2012 | Televison & Video
Denon AVR-4806CI won't turn on.
you must check first the fuse in the power supply which getting blown.if the fuse blown with darkened black color that was mean there are other component parts in the power supply or in the board which get bad. if you know how to test component, check shorted bridge type diode as will as regulator ic and FET transistor in the power supply board.
Aug 16, 2012 | Denon AVR-4806 Receiver
Green power light flashes 3 times then repeats
The defect is likely a sensitive component to over voltage (lightning) on the main power supply. But you should not exclude other boards too, since ohter board also have local power supplies and sensitive CMOS integrated circuits. Check all MOSFET transistors on the the main power supply, since they are the most sensitives. Also the regulator IC to control the PWM sent to the MOSFET is made of CMOS (sensitive). Then check all the diodes even if they are more robust to lightning. There is a MOV that absorb the lightning that could be shorted but in your case it seems to have survived.
Sep 21, 2017 | Toshiba 55ZV650U 55 in. LCD HDTV
My 32lg30 was shorted out during a lightining strike in a storm the other night. plug it in, and press power, and now nothing works. reset button or replaceable internal fuse? I am tech savvy so I can do...
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the entire power supply board, click this LINK.
Hope I helped you.
Thanks for using fixya.
Jdvillanueva
Jun 04, 2011 | LG 32LG30 32 in. LCD HDTV
Dead Set after power surge
Check the power supply transformer primary driver transistor and the associated components (some diodes and capacitors, resistors, an optocoupler maybe) and the rectifier diodes (or a bridge) and capacitors at the transformer secondary, what you are looking for is a short circuit, however, the short may as well be in another section of the circuit board (a shorted component may sometimes have signs of damage caused by heat, but this is not a rule).
Hope you can find out what it is...
regards
Triarcuate
Oct 01, 2009 | Televison & Video
Dec 11, 2007 | Kenwood VR-407 Receiver
Sony dav-sc5 power problem
it is power regulator ic and must be changed.
you must check around ic pins for short capacitor or burnt resistor to complete your job
Nov 01, 2007 | Sony DAV-SC5 System
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
