Question about Danby Premiere DPAC11010 Portable Air Conditioner
Evap fans for dpac11011
Need to know where I can get this part from
Compressor not running
id try a new capacitor (cheapest solution) , but sounds to me that your compressor is done for. id bet the evap coil is quite dirty , this is a usuall cause
Jul 21, 2015 | Haier ESA412K 12,000 BTU Energy Star...
Model 580.51450100
Go by a local air conditioner supply house and ask them. Usually if they can't get the part they know where to go to get parts for home appliances like Dehumidifers. Take the fan motor with you they may have something on the shelf that will work.
Jul 15, 2013 | Kenmore 54501 Dehumidifier
Fan Runs On and Off
the problem is dry bushes on the fan shaft. It is best to replace the fan motor unless you have a good appliance electrician who can pull the motor apart ad knows how to lubricate the bushes.
Jun 09, 2013 | Haier HD308 Dehumidifier
The fan in the dehumidifier makes an awful lot of noise.
It may not be the fan, as much as it the compressor vibrating. This occurs if the unit is not sitting on level flooring or on a carpet. Why I carpet? I do not know, but my LG unit does the same thing. I have found that smacking the sides of the cabinet simultaneously with my open hands, stops the vibration and the noise.
if however, it is the fan making the noise, it too can be affected by an UN-level surface. In addition, the fan shaft made need lubricating. WD40 works well for this or light machine oil (like sewing machine oil) will work too.
Hope this helps you & thanks for choosing FixYa.
Sep 20, 2011 | LG LHD65EBL Dehumidifier
When the compressor is running, should the fan also be running??
yes
whenever the compreesor is running you ned the fan to run for two reasons
1 to cool the compressor
2 to sling the condensate on to the evap to keep that from building up frost
Oct 27, 2009 | Kenmore 54501 Dehumidifier
My kenmore dehumidifier compresor runs the fan runs but no water in the bucket . Compresor freon lines both same to have the same tempature ( flow and Return ) . Is a freon charge the answer ?
More than likely not. I would start by making sure all coils are clean, (both evap and condenser) and to make sure airflow is not being obstructed. Most factory charges appliances don't leak refrigerant and therefore should not have to be charged during there useful life. Hope this helps
Sep 22, 2009 | Kenmore 53509 Dehumidifier
Goldstar dh305y6.will olny run sometimes then shuts off it does collect water but it will olny run a few minutes. other times will not run at all it a dehumideifier
Sound like you need a good cleaning of the evap and condensor. The make sure the fan is running. If nothing runs then check your thermostat.
Aug 31, 2009 | LG DH30 GoldStar Dehumidifier
Fan
For model M7DH45B2A Maytag 45 PINT Dehumidifiers
Parts for the unit. www.appliancefactoryparts.com
Part CRCFD5303-010 Fan - $19.99
Part CRCFD3000-030 Motor - $49.99
Parts for others are also available.
Sep 09, 2008 | Maytag M7DH45B2A Dehumidifier
A7dh65b2a
Normal operation, the unit has sensed icing and is in the defrost mode (compressor off and fan on high). When the ice melts normal operation will resume.
Dec 07, 2006 | Fedders A3DH30B2A Dehumidifier
Danby Premiere DPAC11010 Portable Air Conditioner Logo
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
