Question about a4 bolt, with polygon socket hd. combi. . automatic
I need to make a polygon for free - a4 bolt, with polygon socket hd. combi. . automatic
    Master:
  • 710 Answers
Can't be done.
Posted on Sep 01, 2014
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
signal is detected for 1sec during rotation of the
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
How do convex polygons differ from non-convex polygons?
A convex polygon is one with each of its interior angles less than 180 degrees and every line segment between any of its two vertices remains inside or on the boundary of the polygon.
150px-pentagon.svg.pngExample of a convex polygon (WIKIPEDIA)
A concave polygon will always possess an interior angle with a measure that is greater than 180 degrees.
150px-simple_polygon.svg.pngExample of a concave polygon (WIKIPEDIA)
Aug 11, 2011 | Computers & Internet
I have a toshiba photocopiar and this copiar problem disply of error L 6 10 code pl resolved/ solution problem
The polygon motor does not rotate. The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock signal is detected for 1sec during rotation of the
polygon motor.
Cause:
Improper connection or disconnection of the polygon motor and the harness.
MCU PWB abnormality
Check and remedy:
operations.
harness/connector.
Jun 02, 2011 | Toshiba e-Studio 161 Copier Copier
I have code SC320 of my copier NASHUA D425
SC320: Polygon motor error
-Definition- [B]
The polygon motor does not reach its operating speed within 10 seconds
after the polygon motor on signal, or the lock signal is not detected for
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
Hi we have a Sharp AR-M208 displaying error code L6-10. Need to know what that relates to and some basic trouble shooting to resolve. Thanks in advance!
L6-10 Content Polygon motor lock detection.
Detail It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Jan 10, 2010 | Sharp AR-M208N Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
I have L6 on toshiba e studio 161
L6 indicates Polygon motor lock detection where it does not rotate.
U can use SIM 61-1 to check the polygon motor operation or not, and the connector/wire harness. If confirm the polygon motor not working, then u need to replace it.
Sep 25, 2009 | Toshiba e-Studio 161 Copier Copier
a4 bolt, with polygon socket hd. combi. . automatic Logo
14 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ray gallant
Tom
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
