Question about Parrot AR.Drone 2.0
Parrot AR.Drone 2.0 does back flip at Takeoff and crashes ?
Drone crashed from 75 ft. replaced two motors , cross bar ,navigation ribbon, at first it would just bob up and down because the front motors would only lift a little bit and drop back down , weird. After a few attempts it flipped at take off and crashed so I quit trying .Message was Unknown Emergency !. Got on the iPad and Updated Firmware but no change. Tried reset switch under the battery .No change. Help ?
5 Suggested Answers
SOURCE: Green and Red Lights on my Parrot minikit slim/chic are flashing
Spoke with Parrot, was told that the batt had been left to run to low and I had tried to use it.
let the batt run right out and all will be ok.
I know put on charge veryday and have to had the problem again
Posted on Jan 18, 2009
dancandoit
  • 436 Answers
SOURCE: My Parrot Ck3200 Ls has worked fine for the past
You will need to disconnect power from the main control box. this will reset the unit. you will need to check the power is wired correct as incorrect power will cause this fault. best take it to an engineer.
Posted on Oct 10, 2009
dancandoit
  • 436 Answers
SOURCE: Parrot CK6100 microphone mount
Ebay
Posted on Feb 08, 2010
sunil06
  • 394 Answers
SOURCE: will this parrot work with a trac phone, motorola
yes it works, when it asks for pin or code just enter 0000-zeros
Posted on Jul 14, 2010
Where can I read about drone 2.0?
There are numerous web sites on internet that happen to be supplying information about ar drone 2.0. These are exclusively made for those people who are looking to purchase drone right after undergoing assessment. To find out more kindly visit this website: http://remotecontroldrones.tech/blog
Sep 23, 2016 | Cars & Trucks
What is the use of Headless Mode in UAV/drone?
The drones have a front and a rear, but with a design that is symmetrical to the point that it's hard to make out between the front and back at a distance.
The working of the headless mode is truly straightforward. You need to position the drone in a manner that its front is your front before taking off.
Since Now you can easily control the drone means left will be left and right all the time, regardless of where your drone is pointing at. It's a wonderful feature you should consider if you plan to take your hobby to the next level but not required in Drones For Kids .
Sep 05, 2016 | Parrot AR.Drone 2.0 Quadricopter...
What are the important factors to consider when purchasing a drone?
Following are the important factors to consider before buying a drone:-
  1. Ease of use.
  2. Durability.
  3. Flight Time.
  4. Extra parts.
  5. Features.
Sep 02, 2016 | Parrot AR.Drone 2.0
How do i replace the body set
http://blog.parrot.com/2012/06/01/ar-drone-2-0-repair-videos/
Sep 07, 2014 | Parrot AR.Drone 2.0
Motors Emergency
If you feel comfortable taking it apart, I would check the wiring to the motor for starters. Motor could be bad even, you may need to replace the motor.
Dec 07, 2013 | Parrot AR.Drone 2.0
Can anyone offer advice on my AR Drone 2.0 problem?
What happened? At Drone flyer/maintainer for 3 years
Dec 18, 2012 | Parrot AR.Drone 2.0
Lights remain red, battery 0%,and message is "pic watchdog emergency". What is wrong
OK, I found the problem. The ribbon cable to the sonar board from the motherboard was out just a fraction of an inch. Aslight nudge moved it in just a little, but enough I guess, it works now.
Dec 15, 2012 | Parrot AR.Drone 2.0
AR DRONE 2.0 USER GUIDE
And your question ??
Jun 30, 2012 | Parrot AR.Drone 2.0
We have a GYROS S107G and when we lift off the hellicopter immediately starts to lose control and the balancing bar seems to hit the upper blades causing it to crash. Also, the side braces which hold the...
The top of the main shaft is probably broken. There are 2 pins that hold the "head" for the main blades straight and are probably sheared off. This is causing the balance bar to hit the blades and cause it to crash. You could try the crash kit here: http://www.helipal.com/spare-part_v-max-parts_syma-s107.html
Jan 09, 2011 | xheli Syma S031 Outdoor RC Helicopter
Parrot AR.Drone 2.0 Logo
55 people viewed this question
Top Parrot Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
