Question about Honeywell Surround HZ2200 / HZ2204 / HZ2205 Compact Heater
I lost my operating manual...I want to know more about the features. Also their is a button on the top to the heater that looks like a sun and half a sun...I don't know if that is for heat...or day and night?? Also,when I have the heater on air blows out...
  • Anonymous Nov 08, 2007
    reset room temperature, how do you do it?
    Problem Solver:
  • 9 Answers
A link to an Adobe (Acrobat) Reader format (.pdf) owner's manual for Honeywell® (Mini Tower) SURROUND HEAT™ HEATER FAN Models HZ-2200 (charcoal) and HZ-2204 (white) is here.
Some text from the manual:
• The Surround Heat™ Heater is designed to
disperse heat in either a 360° range or in one direction only.
• To select the desired heating mode, slide the Direction Control switch, located
on the top of the heater, to the position of your choice:
– to the right (full circle) for 360° Heating
– to the left (half circle) for forward only heating (One Direction
Select the appropriate heat dispersion mode. (See
Set-Up instructions.)
• With the Power knob in the OFF position, plug the
heater into a polarized 120V outlet.
• Turn the Thermostat control fully clockwise to the
HIGH setting.
• Turn the heater on using the Child Resistant switch
(Power knob). To operate the switch, push down
the two sides of the Power knob while turning it
clockwise to the desired position. The power
light will illuminate. The Child Resistant switch helps
ensure that the heater can not be turned on accidentally.
• When the room reaches a comfortable temperature, slowly turn the Thermostat
control counter-clockwise until the heater goes off. This is the point at which the
Thermostat setting equals the room temperature. At this setting, the Thermostat
will automatically turn the heater on and off to maintain this selected temperature.
• Push down and turn the Power knob to OFF and unplug the heater when you
are finished using it.
Posted on Oct 04, 2008
Windows dont work
lost operators, manual.
sun roof, can be 3 things
motor. dead.
3 fuse boxes (iml looking on online fsm)
fuse box 3 contains, fuse 32 and 45.
fuse 32 runs , "IG2-SIG-15a)
roof, and
Radiator fan relay #1
Radiator fan relay #2
Radiator fan relay #3
A/C compressor relay
Seat heater switch (Driver side)
Seat heater switch (Passenger side)
Sliding roof unit
Blower motor relay
id bet it is not the fuse. see why? the blower, would be dead.
fuse 45: all is only S/R that is the label too.
this box is long and skinny
with 3 relays on left
2 fuse top
11 fuses, in horz middle.
10 fuses on bottom row. fuse 29 bottom right.
fuse 39 center right
and top 2 are 51 and 50 , left to right
Nov 26, 2013 | 1995 Jeep Grand Cherokee
I don't understand anything about changing the display settings on my Acer p215h monitor I push the buttons but can't figure out what to do
umm...usually if it is a desk top there will be buttons either on the side, front or back or even the top, one looks like a sun and another looks like a square thats normally half white and half black. they are your brightness and contrast...push either end of the buttons to adjust more bright or less bright, more contrast or less contrast.
Sep 16, 2012 | Acer P215H LCD Monitor
I lost my operating manual and would likd to download the instructions if possible
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
Nov 07, 2010 | Honeywell HWM-330 3 Gallon Humidifier
Need manual for econair air-condition
Take batteries out of the remote control. wait a minute till display is empty then return batteries. The display then alternates between a snowflake and sun, you touch any button when it reaches the sun. If you misjudge timeing try again from the beginning. You do the same when returning to cooling.
Jul 28, 2010 | Heating & Cooling
My patio heater snapped off, in half, where the pole meets the base. It was on a deck that has walls so it isn't like there was even a lot of wind hitting it. Anyone know if I can get this covered? I have...
The Warranty information is on page 12 for the HSS-A-SS model. I had the exact same thing happen to my patio heater and am interested in any response from people that have had success getting this problem fixed in a fair manor.
The failure on my patio heater was at the weld of the lower pole to the base flange. I'm an engineer and know that that weld should not fail without a huge stress and lots of obvious bending around the weld prior to failure. Mine had no signs of bending around the failure so I believe this is a faulty or very low quality weld issue from the manufacture. I called the number in the manual and was basically told that they do not warranty tip overs but I could take it back to Home Depot and see if they would replace it. I never mentioned that my heater had tipped over! Garden Sun is obviously not in the business of protecting its name and will put words in your mouth to try and get out of something that is obviously a product quality issue. They appear to be exercising loop holes in the Garden Sun warranty. I'm sure there are other loop holes as well because the representative asked me if I had pets (what does that have to do with the strength of their product).
Please pas along if and how you were able to resolve this issue and I'll update if I'm successful at Home Depot.
Apr 08, 2010 | Stainless Garden Sun Steel Propane Patio...
Problem with used honeywell surround HZZ 2200. run for a minute then shut off.
the way i got mine to run is by pulling off the thermostat knob and then grab the pin and turn it the same way as to turn it up it will loosen it seems it has a mechanical thermostat and its pressure based so adjust it as needed and you can even put the knob back on ... gl
personally i just removed the pin entirely so it runs non stop dunno if that disables any safety features .....
Feb 19, 2010 | Honeywell Surround HZ2200 / HZ2204 /...
Honeywell Surround HZ2200 / HZ2204 / HZ2205 Compact Heater Logo
926 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
