Question about Krups XP4600 Silver Art Espresso Machine Silver Art Espresso Machine
Xp4600 nozzle o ring - Krups XP4600 Silver Art Espresso Machine Silver Art Espresso Machine
Low water pressure
Water inlet filter lime or dirt , 2 nozzle dirt 3
floss with o-rings valves 1 valve has dirt or broken o-ring between 1 of the valves 4 pressure control valve was not screwed. the nozzle (if it is a dirtkiller) is is broken mostly porcelain.
Oct 01, 2015 | Northstar Garden
Tip
AMH nozzle falls out repair.
If you cannot find a replacement as they have been discontinued. Try this. Remove the retaining ring and gasket. Take a empty 20oz generic water bottle such as Walmart or Ozarka. A thin plastic bottle. Cut the top out so it will allow the nozzle to fit very snug through the hole. Then trim about 3/8" to 1/2" more material off the bottle. You end up with a V shaped piece. Put the nozzle through the hole and add the gasket and Retainer ring. The plastic makes up the space where the nozzle wore thin. Once replaced in the tub it will still be able to rotate.
on Feb 25, 2014 | Jacuzzi Whirlpool Bath AMH Spa Jet Nozzle...
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
Eam3500 steam nozzle o rings need replacing
The nozzle should screw out anti clockwise allowing access to o rings, persevere anything can be repaired.
Nov 21, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
My duet washer is leaking beacuse the seal is not aligned right, the metal ring that holds the seal in keeps popping ou..any advice?
Carefully pull the nozzle from the window washer tube. Separate the plastic gasket ring from the nozzle. Insert the nozzle through the hole in the boot and slide the plastic gasket ring down the shaft of the nozzle so that the boot is securely trapped between the gasket ring and the nozzle ridge. Insert the nozzle shaft into the window washer inlet tube and insert the end of the water inlet tube into the boot. Fit the boot around the front lip of the tub so it rests smoothly and evenly. Fit the boot clamp around the front lip of the tub and tighten the screw. Be careful not to over tighten this screw. Damage to the boot clamp or the boot could occur.
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Have dyna glo forced air kerosene heater, 65000 btu. It's about 10 years old. Not getting fuel to nozzle. Cleaned fuel filter; replaced hoses; cleaned nozzle. air pressure gauge shows pressure OK.
Are the hoses on the fuel nozzle right. Air hose to the front and fuel to the rear. Did you remove the nozzle from the adaptor to check the o-ring? Let me know what you find.
nitensheaterservice@earthlink.net
Niten's Heater Service on Facebook
Jan 13, 2011 | Dyna-Glo Heating & Cooling
Need assembly instruction for gaggia titanium steam wand. doesnt seem to go far enough up the tube after i cleaned it
Slide the large sleeve off, now you have just the shorter plastic nozzle with the rounded cap. Unscrew that cap - hold the plastic nozzle with one hand while twisting the cap to unscrew it.
Inside is a hard plastic ring and a soft rubber sleeve. Sometimes the soft rubber sleeve will not come out of the nozzle - if so then just leave it in - but if it will come out, take it out and clean everything really well.
OK ... now put the cap on the steam pipe, then the hard plastic ring, then the rubber sleeve - and slide them up high enough on the pipe - then slide on the nozzle last. Then tighten the cap down on the nozzle until it is gripping good and tight. Then slide the long outer sleeve and you should be good to go.
Oct 01, 2010 | Gaggia Titanium Espresso Machine
Carpet attachment with beater brush not working
Resolution for Quick Connect Power Nozzle: If you're vacuum is 2001 prior, chances are one of the two contacts in the power nozzle elbow have let go.
The elbow can be disassembled by removing the two screw covers. You will need a flat head and small star. Also, you need to release the retaining clip on the back of the elbow. You will have to remove the elbow completely if it needs replacement. You will then have to remove the top cover of your power nozzle. That is easily done by removing all screws in the bottom base of your nozzle. Once you remove your cover you should see 2-4 screws holding in the elbow
When you remove the cover, you will see metal contact rings and two contacts. If one of them isn't contacting the ring your power nozzle will not turn on. You can try shaping it back into place but from experience the new revised elbow that does away with that kind of connectivity is a lot more effective. The new elbow runs about $40-$60. Between eBay and Aerus Electrolux Dealer.
http://www.ezvacuum.com/electrolux-power-nozzle-elbow-assembly-graywhite-p-3542.html
Jul 12, 2010 | Electrolux Centralux Vacuum
Karcher dirtblaster does not oscerlate the water.
Stripped down the head of the dirt blaster by unscrewing the shaft from the end nozzle(it was quite tight). Removed the white disc from the nozzle using pliers and then cleaned out the 4 holes in the disc. Under the disc is an assembly which houses a ball bearing. I noticed that the ball bearing did not protude beyond the recess which houses it. I PUT TWO SMALL FIBRE WASHERS IN THE RECESS THEN REPLACED THE BALL BEARING. THEN REPLACED THE WHITE DICSC. Noting that the ball bearing protrude by approx 1/16th of an inch.
Re-assembled and the dirt blaster now works perfectly
Feb 20, 2009 | Garden
Krups XP4600 Silver Art Espresso Machine Silver Art Espresso Machine Logo
27 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
