Question about Krups XP4600 Silver Art Espresso Machine Silver Art Espresso Machine
Xp4600 nozzle Frothing nozzle. Steam comes out of top
2 Suggested Answers
SOURCE: The Coffee Machine was not frothing properly. The
try the german specialists - they helped me sort mine. BND Kaffeestudio
Blockfeldstr. 16
67112 Mutterstadt
kaffeestudio@web.de
Posted on Oct 26, 2010
Milk Steamer/Frother
Take off the end bit; it unscrews. Poke a needle through the hole; I find it gets blocked quite regularly. While it's disconnected turn the knob on the right. Steam should come out. If it doesn't there is a blockage inside the machine and you need to get inside it to fix it. But the only blockage I've had is in the end bit.
Jan 07, 2014 | FrancisFrancis! X5 Espresso Machine
We have a Magimix M 200 Purchased at John Lewis Registration No: 278739 approx Dec 2008. We have not got the purchase receipt. The nozzle for frothing up the milk is not working at all so we are unable to...
There might be a blockage in the steam tube or the frothing nozzle itself. Make sure the nozzle is clean and try inserting a pipe cleaner gently into the steam tube to clear any blockage that may be preventing steam from passing through.
Jun 30, 2011 | Vacuums
No steam at frothing station. may be blocked. how can i repair myself??
First check the holes in the nozzle of the steam wand, if they are not blocked then remove steam wand and see if water from the faucet will flow through, if yes then problem is in the machine where the tube connects to the boiler.
Nov 23, 2010 | Pasquini Livietta Espresso Machine
After using steamer for milk frothing the red light comes on and cannot get esspresso to brew and no more steam or hot water comes out of the frothing nozzle, the water level is fine in reservior, beans in...
The tap valve is leaking inside the machine needs new seals.If moisture is escaped and hit the printed circuit card on the tap, the machine will stop you from doing other functions.
Feb 05, 2010 | Saeco Odea-Giro Espresso Machine
When I try to make espresso with my new XP2070, water comes out through the steam arm and not through the nozzles. I've tried it without coffee and all the water still comes out through the steam/hot water...
David, the XP2070 won't operate properly until you've set the clock on the unit.
In case you don't have an owner's manual, I've attached a copy of the manual from the Krups site that you can download and print for free.
Please take some time to reaquaint yourself with the setup and procedure for using the expresso portion of the unit, as you might just have some sequence issues that is preventing the expresso from getting brewed.
Otherwise, it could be that the unit has a faulty seal in the pressure vessel that isn't allowing the expresso side to function properly, hence the reason the water might be coming out of the frothing tube instead of through the expresso brewing section.
http://www.krupsusa.com/NR/rdonlyres/C308FB44-1EC6-4119-A060-C73BD65F4789/7355/XP2070espresso.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Frother builds up too much pressure and explodes off the machine
I had the same problem. All you need to do is take the steam nozzle apart and clean it. I tip can be cleand with a neadle. Just make sure you unblock the little side holes and make sure to thoroughly clean the little hole in the front. Over time the milk builds up in the nozzle, clogging up the "steam holes", so the preassure gets too big and the rubber attachments can't hold it any longer. Hope that helps.
Jun 05, 2009 | Jura Capresso F8 Espresso Machine
Where to fine a owners manual
I own a Maxim Expres machine. I no longer use it nor have the manual, but the following are my recollections.
I have the version with an on/off switch on the front and a separate knob to control the steam nozzle.
- Use the carafe to measure the water, then pour into the tank and replace the screw-on lid.
- Measure coffee into the metal basket (don't remember the proportions of coffee to water - you
have to experiment.)
- I tamped the coffee lightly - not as much pressure as you use with a pump-driven machine.
- Put the basket into the handle, line up the slots and twist the handle to the side to secure (I'm
sure the models vary in this regard). Place the carafe under the drip hole.
- Push the button to "on". For espresso, just wait until it stops dripping. This is a steam-driven
machine - don't expect much or any crema.
- Frothing: If you are going to froth milk, you need to do it WHILE THE COFFEE IS DRIPPING.
-Wait until coffee starts dripping into the carafe (otherwise there is not enough steam pressure)
-Submerge the nozzle tip under the surface of the milk and turn the knob on the steam nozzle.
-After frothing, turn the nozzle to closed and wait for coffee to finish.
-If you wait too long to start frothing, the coffee will finish and you will lose steam pressure.
That's what I remember, hope it helps.
May 25, 2008 | Coffee Makers & Espresso Machines
Frothing arm produces a lot of hot water with steam
You probably are overfilling the steam reservoir. If the unit is showing that it has reached temperature, that is your likely problem.
Dec 27, 2007 | DeLonghi BAR 140 Espresso Machine
Steam not frothing properly (very weak output)
It can be the electric magnet valve that has to be replaced.
Aug 07, 2007 | La Pavoni Stove-top Espresso Maker...
Krups XP4600 Silver Art Espresso Machine Silver Art Espresso Machine Logo
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
