Question about RCA Detk185r 18.5" Led Hdtv
DETK185R no enciende
RCA LED 19 TV MODEL DETK185R Usb port was disabled from the factory is there any way to turn ot on
Disabled? What do you plan to use it for? They are used for servicing the tv. They also provide power to peripherals such as chromecast
Nov 19, 2014 | Televison & Video
NEED SOFTWARE FORMATS FOR RCA 19" CLASS LED HDTV DETK185R
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 28, 2014 | RCA 19" Class LED 720p 60Hz HDTV 1.7"...
El tablero de un 99 alero no enciende y el carro tampoco lo trato de encender el carro y se queda prendido por 1o2 segundos y se apaga todo tiene corriente menos el tablero
tengo un alero 99 y no funcionan la cuatro agujas del tablero y tampoco enciende el carro bueno si enciende pero por unos segundo y se apaga espero me puedan ayudar gracias
Sep 20, 2013 | 1999 Oldsmobile Alero
Mi equipo no enciende
usted debe revisar los c.brekaer +fuse tanto en el panel de fusibles de adelante como adentro del vehiculo. vea los diagramas adjunto
Jul 23, 2013 | Cars & Trucks
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
No enciende si hay corriente pero no enciende
Please post in the site language which is English. Thanks
May 31, 2012 | 2004 Jaguar X-Type
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
Timer light blinking tried reset still wont work. unplugged system still wont work
estos equipos aveces presentan filtros danados en la fuente de alimentacion generalmente se ven inflados al cambiarlos se soluciona el problema
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
RCA Detk185r 18.5" Led Hdtv Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
