Question about Garden
Where can I find a user manual for my murray riding mower model 8-38222x27 ?
18hp 42" cut
  • 133 Answers
SOURCE: can't find model number
there should be a data plate somewhere on the tractor with model and ser #. Usually it is under the seat. The motor numbers are usually stamped on the engine cover with model type and code.
Posted on Aug 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: 42'' cut LX2000 Craftsman riding mower
CLICK HERE to go to Sears' parts website
You will need the MODEL number to retrieve the parts list and manual.
If you need help - post the exact model # and I will give you direct links to the belt and manual.
Thanks for using FixYA - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 30, 2009
mowerman1857
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
  • 15 Answers
SOURCE: Murray Mower Manuals
Try the Murray mower website.
Posted on Apr 19, 2010
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
Need wiring diagram for 42 hp murray riding mower model #46576x92b
https://www.murray.com/na/en_us/support/manuals.htmlRQK7IJ
Oct 09, 2015 | Murray Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
Need diagram to replace murray 42 inch cut belt
http://www.ereplacementparts.com/ type in model number of your mower ie 40560x50c All parts and diags ypu need ,Yours Henry
Aug 07, 2010 | Murray 38 Lawn Mower Blade Belt '90'96...
Murray 42'' riding lawnmower owners manual
www.murray.com
Oct 04, 2009 | Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
