Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore electic range Model 790.9611 oven does not work although broiler does; the bottom burner in the oven does not warm up; even when I put it on bake, only the top burner gets hot and it remains red like using the broiler
catriver
  • 878 Answers
SOURCE: burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Posted on Apr 10, 2007
IFIXALL
  • 868 Answers
SOURCE: Oven, broiler don't work
The main control board is what you need to replace here.Please Rate This !
Posted on Jul 06, 2008
docjohn174
  • 943 Answers
SOURCE: Kemore gas Oven /range - oven very slow to warm and gas leaks but Broiler ok
Hi thanks for the question. the problem you are having is with the igniter in the oven. it ignites but not hot enough to burn all the gas. replace the bake igniter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 08, 2008
SOURCE: Kenmore Propane Range won't bake
oven or broiler wont work stove top works fine
Posted on Feb 21, 2009
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have no heat coming from the oven portion of my kenmore 790 electric range after hearing a "pop" sound. fyi, the element looks intact.
Top burners are working, broiler is working, bottom oven burners dont ignite and dont heat the oven? What can we do?
Dec 30, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Broiler does not work!
rEPLACE BROILER ELEMENT. LOOK INSIDE OVEN, FIND SCREWS ATTACHING ELEMENT TO BACK PANEL. TURN OFF POWER. REMOVE SCREWS, SLIP OFF WIRES.
Oct 21, 2009 | Kitchen Ranges
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Jul 06, 2008 | Kenmore Kitchen Ranges
Oven will not work,burners and broiler all work fine
under the floor of the oven, possibly can be see by removing the bottom drawer. the ignitor is hte most common aprt to go bad in any gas oven, visually it might not even look broken though and some even appear to glow(just not strong enough to open gas valve
Mar 01, 2008 | Kenmore 78570 / 78571 / 78572 / 78574 /...
790.7921
Does the bottom ignito glow when the "bake" option is selected? If not, replace the ignitor. Even if it glows, it may not be achieving the electrical resistance value needed by the safety valve to open thus allowing the gas to flow to the burner.
Aug 23, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
Burners don't receive gas though oven/broiler does
Apr 10, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
32 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
