Question about AO Smith 1.5hp Pool Pump Motor 2 Speed Ao Smith Electric for Motor Pool & Spa Pump Bn34
Conversion diagram for 2 speed motor ao smith
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
john224
  • 1378 Answers
SOURCE: How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Posted on Jul 26, 2009
john224
  • 1378 Answers
SOURCE: I have a AO Smith Century Centurin Swimming Pool
A.O.Smith USQ1152.
Posted on Jan 18, 2010
thepool
  • 78 Answers
SOURCE: Need manual for D1036 AO Smith 1075/3 SPD 48Y Frame 1/3 HP motor
AO Smith will send you a manual. Contact info http://www.aosmithmotors.com/contact/contactform.aspx?ekmensel=fb5d653b_6_16_btnlink
Posted on Apr 21, 2010
adamh294
  • 310 Answers
SOURCE: Leaky 4 HP hot tub pump seal AO SMITH motor, pump
If you have removed the impeller this is what you need.
Part number for your shaft seal is : 37400-0028s
Here is a link to the manual on how to install / remove this seal on this pump:
http://www.hottubs.com/content/pdf/Sta-Rite_Dura-Jet_S377(9-12-03).pdf
Refer to page 9.
This seal can be purchased anywhere on the internet. Just do a google search with only the part number. Many suppliers will come up. If you have trouble, I have a few and can make an E-bay sale for one.
Posted on Nov 15, 2010
Testimonial: "Thanks, and especially for the link to the manual. This is exactly what I needed. Mark"
How to conect a 230v cooler motor
The wiring diagram should be on the junction box cover. You can go on line and download the manual with this information. There are a lot of A.O. Smith motors out there.
Apr 24, 2014 | A.O. Smith Plumbing
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Replaced an old Magnetek century two speed with a AO smith century two speed. Hooked the wires up the same but unable to get the motor to operate in the high speed mode, suggestions!
Each motor will have wiring diagram on label.
Compare diagram on old motor with new motor.
WIRE COLORS VARY
Which 2-speed timer do you have on the circuit?
Wire lead from NO terminal connects to High speed.
Wire lead from NC terminal connects to Low speed
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Oct 23, 2012 | Pool & Spa
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
Need wiring diagram for BN34 motor 2 speed 1.5 hp 230 volt
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Aug 16, 2011 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
First stage of my 2 speed hot tub ao smith pump doesnt work electrcian says switch is not lined up right?
these are a hard motor - pump to work on. i would take it to your local pool pump motor repair guy who has free motor testing , un plug the motor from the control box not at the motor, if you do take pictures or make a diagram of each wires place ! if you hook it up wrong you can BURN THE MOTOR UP AND THERE IS NO FIX'N IT. sept for a new motor $$$ yuk .take the pluming lose and leave the pump on the motor.... good luck .. hope i was a little help if so please leave feedback .. Jay THE PPMRG FLORIDA
Aug 01, 2010 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
AO Smith 1.5hp Pool Pump Motor 2 Speed Ao Smith Electric for Motor Pool & Spa Pump Bn34 Logo
32 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
