Question about Neewer Digital LCD Display Wind Speed Scale Gauge Anemometer Thermometer
Neewer anenometer need instructions
My anenometer has stopped working. I have changed the batteries and pressed rest
take the batteries out take the back off dry it with a blow dyer on low be careful not to melt anything you can also put in in ajar of rice and the rice will remove the moisture this may restore it to working order and it may not it could be shot but I have fixed cell phones this way that has been dropped in water
Jan 29, 2014 | Measuring Tools & Sensors
When i open my internal flash on my 1100d there's show up problem.err 50, whats happen with my camera?how to fix it?
you could check online and see if there is a firmware update for the camera? or it could be an actual physical part on the camera needs replaced? would be really frustrating i imagine. another solution would be to get an external flash like the $40 neewer tt560 and see if it works with camera? it is miles ahead of the onboard flash anyway and is a good investment to any photographer! and the only other suggestion is to upgrand to T3i (600D) or T5i (650D)
Dec 12, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
Neewer mirror led watch setting instructions
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 12, 2012 | Cars & Trucks
Neewer eza-c1 manual
EZA-C3 Manual, only difference is the plug that fits the camera...
http://www.scribd.com/doc/100733549/EZa-C3-Digital-Timer-Remote
Jan 30, 2012 | Cameras
Help Please ASAP. NEED Assembly Instructions
lbehrman
Here is the instructions on their site.
http://www.woodcrestmfg.com/instructions/instructions.htm
Hope this helps
Issken
http://www.fixya.com/users/issken
May 08, 2010 | Baby Gear
Need online instructions for the Mega Blocks set DRAGON MOUNTAIN
You can download the instructions from here:
https://support.megabrands.com/en/customerservice/instructions.php?brandSelect=3
or the direct link is:
https://support.megabrands.com/media/playbooks/9858.pdf
May 30, 2009 | Mega Bloks Mega Brands Lil' Fire Truck
Need Assembly instructions for Evenflo crib model 012616
This is the instruction manual. Found it. Here you go.
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=012616&txSearchDOM=5/7/2003
There's a search option. Put in exact model number and date and it pulls the instructions.
Apr 27, 2008 | Evenflo Jenny Lind Crib
Neewer Digital LCD Display Wind Speed Scale Gauge Anemometer Thermometer Logo
42 people viewed this question
Top Neewer Home Experts
Donni Steen
Tom Chichester
Are you a Neewer Home Expert? Answer questions, earn points and help others
