Question about Kenmore 15864/15862 Top Load Washer
Kenmore Dryer 70 series washer agitator sounds like its skipping
My washer does okay washing clothes, but when it's washing, it sounds like the agitator is skipping (or something is) inside the tub. How do I take the agitator off to check it out? where do I get a new one?
  • 5,911 Answers
Remove the center cap, or fabric softener dispenser (if installed) from the agitator center post. There should be another cap (used as an air gap) under the center post cap. Remove the cap and locate the agitator bolt. Using a socket and ratchet, hold the agitator still with one hand and loosen with other. The upper portion (called the auger) should lift off, first. Then, grasp the agitator by the flanges at the bottom of the wash tub and lift straight up. This will reveal the gearcase (transmission) shaft.
Now...is the entire agitator slipping? Or, is it just the auger? If the auger is slipping, you may just need to replace the agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Read through the link provided and let me know if you still need assistance. I hope this helps you.
NOTE: If the dogs are worn and need replaced, you only need to remove the auger and not the entire agitator.
Posted on Jun 22, 2009
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Series 70 washer make a clicking sound when
could be your motor coupling, something stuck between the agitator and drum, tranny
Feb 14, 2010 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series barely agitates and makes a clicking sound
What u have just described are failed agitator pawls/dogs, relatively easy fix. The repair comes as a kit. Most appliance repair houses will have the kit, if not www.searspartsdirect.com will have them
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Won't agitate or spin
Probably the motor coupling has cracked. Located between the motor and transmission/gearbox.
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
259 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
