Question about Microwave Ovens
Bosch 500 Series HMT5050 install instructions
BOSCH Microwave HMT8656 change the clock??
Google (bosch)(HMT8656)(manual) without parens for instructions.
Jun 01, 2018 | Bosch Microwave Ovens
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
Bosch hmt 845k microwave oven
If for some reason you don't still have the installation instructions, their support site should allow you to either download or order a set.
If you can't find their site, try the dealer from whom you purchased the oven.
Jun 09, 2013 | Microwave Ovens
Microwave shuts off after 22 seconds
Any product that uses electronic parts is subject to failures. That's why warranties exist. Contact Bosch on their webpage to get assistance.
Nov 16, 2017 | Bosch 500 HMB5050 Microwave Oven
My Bosch microwave (built in HMB5050 has stopped heating all of a sudden. Everything else appears to work fine but it does not heat. What is the problem?
I have the same issue, plus mine shuts down after 30 seconds. There are a few other similar issues on here, with solutions including unplugging it for 10 seconds, replacing a fuse, and replacing half the internals. Please post your fix if you find one!
Jul 28, 2011 | Bosch 500 HMB5050 Microwave Oven
No installation Instructions or Owners Manuel
Although you gave an incomplete model number, Owners Manuals, Installation Guides, Warranty Guides and Part Lists can be found for the entire MH3184 series on this page: Whirlpool Product Literature/MH3184 Series
Hope this helps!
Aug 05, 2008 | Whirlpool MH3184XP Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
