Question about Cooking
8y tyler went **** in the toilet.
Why is it flashing code 8Y?
88 8Y is a icemaker error code if no icemaker on that model,not sure you may have to get samsung invovled.
Jan 16, 2016 | Samsung RF265AA Bottom Freezer French Door...
My power went out got 88 code left 88 - 8y on right display. No water comes from dispenser, everything else OK.
There is a solenoid on your machine that lets in water for the dispenser. Make sure that the solenoid is receiving power. If no power check the switch - if power, the solenoid may be stuck shut - happens. Sometimes a good whack will unstick it! .
Aug 24, 2015 | Refrigerators
8x + 3y = 3 4x + 5y = -23
This is best written as two separate equations:
8x+3y = -23 and 34x+ 5y = -23
Solving the first one for x:
8x = -23-3y
x = -23/8 - 3/8y
Substituting this value for x into the second equation:
34(-23/8 - 3/8y) + 5y = -23
-97.75 - (34)(.375)y + 5y = -23
-97.75 - 12.75y + 5y = -23
-97.75 -7.75y = -23
-7.75y = 97.75-23=74.75
y = -74.75/7.75 = -9.645161
Substitution back into the equation for x:
x = -23/8 - 3/8(-9.645161)
x = -2.875 + 3.616935
x =.741935
Dec 12, 2014 | Bagatrix Algebra Solved! 2005 (105101) for...
Tiled bathroom floor. Went to install toilet
hi, the tile is supposed to go under the toilet flange (the thing you put the wax ring on), very common "oops", can be rectified by placing another wax ring right on top of the first on. best to make the first one a "horn type" wax ring, then put the plain one (no horn) on top of first and try to smoosh it on just enough to stay in place so when you install toilet it doesn't move,.....cheers!
Jan 31, 2010 | Kohler Cimarron 2-PC Elongated Toilet with...
Went away for 8 days, came home to no water in the toilet bowl or the tank. Put water in tank, and toilet bowl, flushed, water went away and still no water in tank or bowl. Help
Thanks for all your information. A neighbour came over and saw that it was the tank valve that had broken and so he went out to Home Depot, bought the part and it's now working. Yeah!!!
Dec 28, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
8y-4(5-6y)+20 distributive property
You are talking of the distributivity of multiplication with respect to the addition or subtraction. The only term where you have multiplication and addition/subtraction is the one with parentheses because
4(5-6y) = 4*(5-6y). * means multiply by
Distributing the product consists in removing CORRECTLY the parentheses.
I consider the term alone
4*(5-6y) = 4*5 +4*(-6y)= 20 -4*6*y = 20 -24*y
You put this result in a package and replace it where it was it the original expression.
So
8*y -(package) +20= Replace package
8*y -(20-24*y)+20 = 8*y -20 -(-24y) + 20 Remember -*(-) = +
8*y -20 +24*y +20= Remember -20+20 =0
8*y -20 +20 +24*y= Addition is commutative
8*y +24*y = 32*y
Let y be an orange 8 oranges + 24 oranges =32 oranges.Coclusion
8y-4(5-8y)+20 = 32y
Sep 10, 2009 | The Learning Company Achieve! Math &...
4x+8y=20 -4x+2y=-30
4x+8y=20 || /4
x+2y=5
x=5-2y
-4x+2y=-30 || /2
-2x+y=-15
-2(5-2y)+y=-15
-10+4y+y=-15
5y=-5
y=-1
x=5-2y || y=-1
x=5-2(-1)
x=5+2
x=7
Mar 10, 2009 | Bagatrix Algebra Solved! 2005 (105101) for...
Determining the equation of the parabola
V (2,0) and Focus (2,2)
since the focus is 2 units above the vertex, the parabola opens upward
vertex (h,k)
a is the focal length (distance between the vertex and the focus)
a = 2
(2 units above the vertex)
(x-h)^2 = 4a (y-k)
(x-2)^2 = 4(2) (y-0)
x^2 - 4x + 4 = 8 (y)
x^2 - 4x + 4 = 8y
x^2 - 4x - 8y + 4 = 0
**Answer: "(x-2)^2 = 8 (y)" or in expanded form "x^2 - 4x - 8y +4"
Nov 18, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Cooking Logo
321 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
