Question about Ricoh Office Equipment & Supplies
How do i clear the J001 error on a Ricoh MPC5501A?
2 Suggested Answers
n1yap
  • 3 Answers
SOURCE: j001 error code in ricoh aficio mp5001
need need new tires in tray 1
Posted on Nov 14, 2012
Ricoh Aficio 3228c misfed paper j001. paper jam
This means the machine has been turned on with a jam inside the machine someplace. If you have opened everything in the machine and found nothing then it is time to call a service technician.
Aug 03, 2017 | Ricoh Office Equipment & Supplies
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Reset aficio error sc738
what is the problem ricoh j001
Sep 10, 2013 | Ricoh Aficio 250 Copier
I have a ricoh aficio 2022 and the problem is that sow error j001 jam at the c section but there is no paper stuck on the printer
first is clean the sensors especially the exit sensor, check also the door switches maybe they are not functioning well so the jam will not be reset
Jan 22, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
Error code J001 shows up after a jam
ricoh mpc3500 paper jam j001 which sensor ,no have inside paper
Jul 06, 2011 | Ricoh Aficio 250 Copier
I have a aficio mpc2500 with a fault J001, I cleared the paper but is there a reset button for this
no reset button>sounds like one of the feed sensors still seing the paper or possibly covered in dust and its thinks there is still paper jam. Take all the trays out look inside see if there is any paper in there. turn the copier on with no trays in the copier.Hope that helps.
Nov 13, 2010 | Ricoh Office Equipment & Supplies
Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
ORIGINAL MISFEED (J001)
open the adf cover and clean all the sensors
Nov 18, 2009 | Ricoh Office Equipment & Supplies
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
