Question about Sony PlayStation 2 (PS2) Console
Ps 2 magicgate when i put in dvd it says this movie will not play due to the current parental level setting of the player. what do i do
  • 34 Answers
Put in your code. (If you havent ever changed the code try 0000)
Posted on Jun 23, 2009
When I put a dvd in the sony playstion 2 slim it says (This movie will not play due to the parental setting of the player) how do I remove parental restrictions for dvd's & cd's Thanks
In settings there is the parental lock code. If Bought Brand new, then the defaut password is usually 1234, so give that a try. After which you can set it to the most allowing setting, which i believe is 8 and then any movie shoud play. However if you have set a password then you either need to reset it with a PS2 format disc.
Please Rate
Sep 05, 2011 | Sony PlayStation 2 Slimline Console
I have a Toshiba SD-K730 DVD Player I am trying to set the Parental Lock limit what type of movies are viewed. Can you help?
Parental control setting
Some discs are specified not suitable for children. Such
discs can be limited not to play back with the unit.
1) Press C or D to select "Parental", then press B
or A until the level you require appears.
Level Off: The parental control setting does not
function.
Level 8: All DVD software can be played back.
Level 1: DVD software for adults cannot be
played back.
Select from the level 1 to level 8. The limitation will
be more severe as the level number is lower.
2) Press C or D to select "Password".
Press Number buttons (0-9) to input a 4-digit
password. Be sure to remember this number!
• If you input a wrong number, press CLEAR.
3) Press ENTER to store the password.
Note: Now the rating is locked and the setting cannot
be changed unless you enter the correct pass
word.
4) Press OPEN/CLOSE to activate Parental control
setting. (See "Temporary disabling of rating level by
DVD disc" on page 36.)
Notes:
• Depending on the discs, the unit cannot limit playback.
• Some discs may not be encoded with specific rating
level information though its disc jacket says "adult." For
those discs, the age restriction will not work.
To change the parental level
1) Press C or D to select "Password".
2) Press Number buttons (0-9) to enter the password
you have stored.
3) Press ENTER.
• The rating is now unlocked.
4) Press C or D to select "Parental", then press B
or A to change the parental level.
5) Press C or D to select "Password", then press
Number buttons (0-9) to enter the password.
Note: You can change the password if you want.
6) Press ENTER.
Now the parental level is changed and locked.
If you forget the password...
1. Press OPEN/CLOSE to open the disc tray.
2. Remove the disc.
3. Press OPEN/CLOSE again to close the disc tray.
"No Disc" appears on the screen.
4. While holding STOP down on the front panel,
press 7 on the remote control. "PASSWORD
CLEAR" appears on the screen.
5. Enter a new password again.
hope this helps
John
Mar 24, 2011 | Toshiba SD-K740 DVD Player
I'm trying to play a dvd but it says that parental controls have been set. I know the passcode is 8888 but when I type that in on my remote (universal, not original) it doesn't even recognize that I've...
Sorry u have to buy an original remote for this.The universal remote,will not be response by the tv for tthis function.Try website like Remotes.com to buy an exact to the original remote.
Oct 21, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
Can't get the Initial Settings screen
Hi,try this...with the dvd tray open,hold the rec button and play button on the dvd for 5seconds.hope this helps?
Mar 25, 2009 | Panasonic DVD-A110 DVD Player
Level change
here it is:
Step1
Place a DVD that prompts you for your password in your PS2. If you have any R rated DVDs sitting around, one of those should work just fine. It should prompt you for the password before anything else comes up.
Step2
Select "Yes" to playing the movie and select "Yes" again to temporarily suspend parental controls. This is where you would put in the password if you knew it and the DVD would play. You may try "1111" at this point, as it is often the password. If that doesn't work, continue through the next few steps.
Step3
Press the "Select" button on the screen that wants you to input the password. This should change the text on the screen from "Enter Password" to "Delete Password."
Step4
Input the numbers "7444" into the box on the screen. This is the universal password needed to delete the current password. Once you input the numbers, you should get a message that says "Deletion Complete." Press the "Select" button again and you should be prompted to enter a new password.
Step5
Enter a new password for your parental control. Make sure it is something easy that you will remember. Once you enter it in, you will be asked to confirm your new password. Enter it one more time and you should be able to watch any DVD you want.
if it helps please rate positvely!!
Nov 05, 2008 | Sony PlayStation 2 (PS2) Console
Tv guardian settings
OK I FOUND IT!!! IT'S 1234, when the parent control screen shows up press the play button then enter 1234 then press play again!!! The movie plays then!
May 08, 2008 | Disney Princess DVD Player
Parental code
You can take your time putting in the code. I mistakenly had the impression
you had to time it just right. But no.
Just close the tray with no disc inside, it will say NO DISC.
On the remote, press MENU, the "non-applicable" slash circle graphic comes
up.
Then press 1, (same slash circle), then press 9, and the menu pops up.
My menu says:
Region : 1
Password : ____
Level : 8. Adult
By default, the region number is highlighted. This is where I got confused. I
pressed the control pad on the remote left and right and up and down and
nothing changed the number.
The only way to change the number is to press ENTER on the remote and it
then cycles through all the numbers available. I was never given a chance to
punch in a number, I tried it and it didn't work.
While I was here, I also set my password code and looked through the choices
for LEVEL. I think it is a system to limit the type of movie that could be
played, for instance, if the DVD player was for a child's room, you could limit
the level to G, PG, or PG-13 and it wouldn't play movies rated worse than
that. good luck
please mark the post with a fixya!
Jan 22, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Soundstorm car dvd player
This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
May 29, 2007 | Soundstorm SDVD-100 Car DVD Player
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
