Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Can I run my heater if the control board has gone blank?
    Top Expert:
  • Jandy Master
  • 3,543 Answers
If voltage going into it and 24 volts ac after transformer then you need a display board
Posted on Mar 05, 2016
Control panel is blank and the gas company checked the pressure, it is at 5. The heater is not activated.
first of all, if the inlet gas pressure was only 5 inches water column the heater will under fire once it runs. that pressure will have a slight drop once the heater is running. So, the gas company should have known that and realized the gas line may have been undersized. Secondly, if the control panel is blank you probably have a problem with the transformer inside the heater. The secondary side will send out 24 volts, the control panel also runs on 24 volts.
Sep 18, 2013 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Hi I moved into a place where the control board for the sta-rite heater was stolen, and the ID tag is blank - no model number or stats. How can I find out what I need?
I recommendyou call the Sta Rite technical support line at 888-782-7483 and they should be ableto help you figure this issue out.
Ihope this helps.
Sep 23, 2011 | Sta Rite STA-RITE CONTROL BOARD KIT -...
I have a Paloma PTG-74PVN tankless natural gas water heater. It was installed 3 years ago and has worked great until 2 days ago. Currently, the water heater will run for approximately 10 minutes, i.e....
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
Dec 16, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Sta rite heater won't fire. Control board only shows green LED lights. Prior to not firing water temp was 120 degrees. Almost burnt my foot off. Next day heater did not fire at all. Where can I go to...
Could be your heat sensor has gone bad. follow the wires for the sensor from the board to the water manifold. Then simply unscrew the old one and put a new one in. Do this with the system off, good luck.
Sep 17, 2010 | Sta Rite STA-RITE CONTROL BOARD KIT -...
I have a Protech 520 nonprogramable thermostat that has gone blank and the HVAC is not running. Is there a battery? If so where and how do I get to it?
first try to remove/disconnect thermostat, touch the 2 wires together to see if the heater comes on, if it does then the problem is in the thermostat, if it does not come on then the problem is either in the wiring going from the thermostat to the gas control valve on the furnace, last, you can trace the same wire to the gas control valve on the heater, try to cross the wires there, with like a scrap peice of wire bent in a horse shoe shape if the heater does not come on still, you may need a new gas valve, good luck.
Jan 13, 2010 | Heating & Cooling
The thermostat is completely blank and no heat is on. The breaker is not tripped, how do i fix?
First, Is there batteries in the t-stat that have gone bad? If you are not sure, pull the face off of the t-stat and check.
If that is not the case then it may be a transformer in the furnace or if you are lucky, a fuse in the control board that blew.
If you have an electrical meter, check for 24v AC at R and C on the control board. If there is no power then the fuse is blown or the transformer is gone.
If there is a fuse then check and change that, they can be blown without it looking like they are.
Did a t-stat wire break or come of??? If the R wire braks or comes off it will totally shut things down...
Heatman101
Dec 29, 2009 | Honeywell Electronic Programmable...
I have a Hayward H400DL2 (post 2004) The front control panel has gone blank, and the keypad has pealed up slightly, allowing water and dirt to get onto the circuit board. It would appear that the rest of...
This front panel is a seperate part from thr board and should be replaced if it is alowing water into the unit and cause more costley repairs.
The slow start is probally clogs in the gas orfaces in the main gas header. You will need a small wrench to unscrew these to clean them. You should start with the ones closest to the main burner; (The one with the ignitor or pilot connected to it). Good luck.
Dec 27, 2009 | Hayward H Series Pool & Spa Heater 400k...
DIRTY DISHES ,HAZY GLASSES.ALL SOAP NOT GONE
Sounds like the heater is not working, could be bad heating element, bad door switch, or bad heater relay on the main control board. Check for continuity on the heater element to rule out a burned out element. Do the same for the door switch, if all checks out good then replace control board with heater relay.
Feb 23, 2009 | GE Dishwashers
I press print. and blank pages go through the printer until paper runs out. i refill with paper and blank pages continue to go through printing nothing at all... its never ending. i have stuff due. what do...
the formatter board has gone bad, If this is a bubble or inkjet machine, then replace the machine as the machine is not worth repairing. if it is a laser machine then the formatter needs to be replaced, may also be a DC control board issue.
Sep 03, 2008 | Canon Office Equipment & Supplies
Dishwasher Bosch shu 5300
best check the heater at source. the heater relay may have gone internally on the pcb.
Feb 16, 2008 | Dishwashers
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
76 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
