Question about Apple Power Mac G5 Desktop
I got Mass Storage error 9972 on my Powerbook/G4, 867MHz. Only Apple logo appears on startup. Tried restart from original CDs. Tried Disk Warrior and Disk Rescue II. Nothing worked. Problem started when I failed to let OS X installer disk finish installation upon Restart. I was waiting so long for machine to restart that I did pushed the buttons to restart it myself. What else can I do? Linda Kawamoto lkawa821@earthlink.net
  • Apple Master
  • 13,433 Answers
Lost power when changing computer name and key. no boot or sys disk. boots to apple logo and spin wheel. how to recover w/o loss of data
Try holding down the option key (ALT) when you boot up and see if you can see your startup disk. Good luck....
May 22, 2016 | Apple PowerBook G4 Mac Notebook
My macbook pro OS 10.6.4 either freezes or crashes on startup. Crashed when trying to startup with Drive Genious 3, TechTool Pro 5, System Disk or Disk Warrior. Not sure what to do next. Tried holding ...
Restart your mac. As it's restarting/booting up, hold down the command, option, R and P keys simultaneously. As it's booting up and you're holding these keys, you should hear the startup chime, continue to hold the keys down, it will cycle and you'll hear the startup chimes again. Let it go thru this cycle 7 (seven) times before you let up on those keys. Once it's cycled 7 times, let it boot up normally.
If that doesn't work, then reinstall the original system software that came with the Macbook. You may have to reformat the hard disk and do a clean install.
Jul 05, 2010 | Apple MacBook Pro Laptop Computer with...
Apple Macintosh PowerBook G3 Start-up problem
Your mac doesn't recognize the system folder. Try to find the original boot disks that came with the machine, and see if you can mount the hard disk while booting from the CDs. If you can, I'd backup the data as soon as possible and reinstall the operating system, including a full hard drive reformat. If you can't see the hard drive from the boot cd, another option is to hold down the T key during startup to boot the mac into "target disk mode" - this will allow you to hook up the g3 to another computer as an external hard disk in order to back up the data.
Oct 21, 2009 | Apple PowerBook G3 Mac Notebook
Powerbook G4 blue screen on start up
Basically some causes of blue screen is the RAM check the RAM remove first maybe it is clogged by the dust. Remove the dust of the memory stick and insert it back to you computer. Usually of you have this problem again you need a recovery disk. Load a windows CD to your CD drive you need to boot and repair the windows.
Regards
nicole
Oct 03, 2009 | Apple PowerBook G4 Mac Notebook
My powerbook G4 will not startup... All that appears on the screen when I try to turn on my computer is a tiny folder with a question mark on it. The mouse pad is nonresponsive.
Computer cannot find operating system files. Start up from Install Disk or Utility disk and re-install system. Hold down C key while starting from disk.
Aug 11, 2009 | Apple PowerBook G4 Mac Notebook
When I turn on my computer I get a grey screen for a few minutes until a blinking folder with a question mark in it appears. Often, my computer shuts off after the question mark folder disappears. I have...
The blinking question mark means that you macintosh can't find a bootable disk. It has nothing to do with the VGA connection. More than likely, your directory structure on the disk is bad. An excellent product to fix this is Disk Warrior. It has saved more hard drives for me than I care to think about. Worth every penny.
As far as booting up from a disk, just put in the CD and hold down the C key until you see the spinning icon.
You could also try these to things if you don't want to purchase disk warrior, but I don't think they will work. Hold down the shift key while you boot until you see the apple logo. The shift key is to boot it in safeboot mode. Or, you could also reset the pram:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Jul 04, 2009 | Apple Mac OS X 10.4
Restore CD
You don't need a "restore" cd.
You can just use any copy of Tiger.
Borrow one!
Jun 15, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook won't start up
If you have the original install CD or the OSX CD, boot to CD. To do that you must insert CD, restart PowerBook and hold letter "C" on keyboard while computer is starting, then take the first steps towards installing the OS, when you get to the bar on the top go to Tool>Utilities>Disk Utilities then select the drive a do a disk repair. That may fix the problem and bring your system back to booting normally.
Mar 15, 2009 | Apple PowerBook G4 Mac Notebook
Powerbook G4 wont start up, shows a file folder with a ? mark....
The hard drive is probably on it's way out. You can get and run Disk Warrior and you could repair permissions and such but the hard drive is probably on it's way to the grave.
A couple things though. It isn't enough to just put the disk in, you need to hold down "c" while the computer starts for it to try to run off your disk. You can then try to repair permissions and fix the disk from the installation program that starts. When the Install OS X screen comes up (looks like a desktop but with the big dialog box in the middle) click on Utilities at the top and then on Disk Utility. HERE IS APPLE'S SITE for you to read about how to try to repair your disk. I've found that this sometimes works and may help it work enough for you to get your files off, but may not.
Another method would be to get another Mac, and hook the two together with a firewire to transfer your files, then reinstall OS X in your ailing computer. Go HERE to read about this technique.
Feb 19, 2009 | Apple PowerBook G4 Mac Notebook
Firelite wont mount on my computer
look at its format, (NTFS) or (FAT32)? and check the DRIVER for the hdd to see if it has any complications or errors, this is easyest fixed by deleting the HDD driver in Device managment and then restarting the computer. good luck.
Oct 09, 2007 | FireLite (USBFLB80) Hard Drive
Apple Power Mac G5 Desktop Logo
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
