Question about Otc Tools OTC 3108N PocketScan OBD II and CAN Scan Tool
Otc 3108n led fail code what does this mean? - Otc Tools OTC 3108N PocketScan OBD II and CAN Scan Tool
The computer symbol came on on my otc stinger obd2 code reader what does that mean the computer symbol ubder the car symbol means what thanks
That function is not enabled yet. It means that you will be able to connect the reader to a computer in the future if they decide to enable it.
May 04, 2016 | Cars & Trucks
Alternator change 2001 tdi
remove the unit from the power for one or two hours
and it will get reset
Oct 16, 2008 | 2001 Volkswagen Golf
Why does the check engine light come on?
connect an obd2 scanner to the port under the steering wheel area & read out the trouble codes
reset the car's computer with the scanner and then see if those same codes come back at a later time
then, proceed with looking up those codes on google search & begin the fixing of the damaged wiring or component
my local autozone or advance auto parts can do this service of scanning for trouble codes FREE in my area of the USA
Apr 16, 2015 | Cars & Trucks
Power indicator just keeps blinking
H16 on this model means that either the power supply transformer has failed, The outdoor PCB has failed or the machine is low on gas.
This info is from the Panasonic service guide. The outdoor unit LED 1 is on, LED 2 is on, LED 3 is off, LED 4 is off.
H16 On On Off Off Current Transformer Problem Power Transistor Module or Outdoor PCB Faulty. Very Low Gas
Mar 28, 2014 | Panasonic Heating & Cooling
What OTC means?
In what context? It can be the Olympic Training Center, the IATA code for the Bol Airport in Chad, over the counter, among others. See http://en.wikipedia.org/wiki/OTC
Aug 30, 2013 | Computers & Internet
My abs lights are on and and the traction control lights keep flashing from time to time. why wont my otc scanner pick up any codes?
Are you using an ABS card? I have a Mac scanner by OTC and I have to use a separate pathfinder ABS card.
Feb 19, 2010 | 1998 Plymouth Voyager
Meaning of rudd furnace trouble codes
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
Dec 12, 2009 | Heating & Cooling
Whirlpool Duet Dryer GEW9250P (electric)
Here is a list of possible causes. NONE OF THE LEDS LIGHT... Check to make sure that ribbon connectors P3 and P4 are inserted all the way into the machine control electronics board. (To access the machine control, pull the dryer away from the wall and remove the three screws from the top panel on the back. Slide the top panel rearward about 1/2" and lift. The machine control is on the left hand side. P3 and P4 are the "ribbon" connectors going into the board.) A PARTICULAR GROUP OF LEDS DOES NOT LIGHT... A group or combination of LEDs share a common electronic connection. If this connection is open, all of the LEDs in the group will be disabled. If this occurs, replace the entire console electronics and housing. ONE LED DOES NOT LIGHT... Press the button associated with the LED several times. If the LED does not light, the LED has failed. Replace the entire console electronics and housing. NO BEEP SOUNDS... If the associated LEDs do light up, the beeper circuit may have failed on the machine control electronics board. NO DRYER FUNCTION IS ACTIVATED WHEN A PARTICULAR PUSHBUTTON IS PRESSED... If the associated LEDs do light up, the machine control electronics board may have failed. AN E3 ERROR CODE IS DISPLAYED... An E3 error code means that there is a user interface or a software mismatch. It can also mean that a component on the console electronics,or the machine control electronics board has failed. Hope this little tutorial gets you where you need to go. Let us know how it turns out, will ya?
Sep 13, 2007 | Whirlpool GEW9250P Electric Dryer
Otc Tools OTC 3108N PocketScan OBD II and CAN Scan Tool Logo
29 people viewed this question
Top Otc Tools Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Otc Tools Measuring Tool and Sensor Expert? Answer questions, earn points and help others
