Question about Pentair MINIMAX NT TSI IGNITER
Pool heater won't kick on
We just bought a minimax 150m pool heater. the pilot is lit and running but unit won't kick on
    Problem Solver:
  • 7 Answers
Check the gas line pressure; (if this was a homeowner installation you will not be able to check the gas pressure) dirty filters are the number one cause of heater malfunction. before you do anything else break the filter apart and clean completely and recharge with diatomaceous if applicable. also check the pump baskets and make sure there is no debris in the basket or blocking the impeller inside the pump. if this doesn't solve your problem call pentair tehcnical support
Posted on Jun 25, 2009
My pilot light is lit but I am not getting fuel to the main source for heater to kick on.
could be pressure switch. that is the most common failure. otherwise, ensure gas pressure to unit, make sure gas valve switch is on (inside unit)
May 26, 2014 | Hayward Pool & Spa
My pool heater Pentair ch minimax 150m has no voltage to gas valve. The pilot is on .
ok is millivolt heater need to check all the safety circuit are getting power ,also check for clean filter ? is the water pressure switch inside the heater is closed ? did u check if the pilot generator is generating more the 600MV ? also check for any loose wire connection ,a 9 volt battery generated more voltage that u pilot generator
Jun 08, 2013 | Pool & Spa
Pentair 250 pool heater
check gas pressure and when it goes out check voltage from transformer
May 28, 2013 | Pentair 250k Minimax Ch Ng Mv Heater
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pentair MINIMAX NT TSI IGNITER Logo
333 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
