Question about Kenmore 64852 Electric Dryer
How does the tensioner fit in below the drum?
  • 5,911 Answers
With the tensioner in your left hand, insert the clip end into the grooves on the dryer bottom casing with the idler wheel pointing to your left. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive belt pulley. If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Posted on Jun 22, 2009
Dryer has a clicking sound when powered to the run position, first I suspected the tension pulley but now I am kind of thinking it may be a motor problem, I sprayed some wd40 on the tension pulley but did...
In addation to the components of the dryer potentionally making the noise ,i have found on quite a few ocassions where a coin or similar object is caught in the seal between the drum and the front and rear bulkhead it fits into,OR a pencil or whatnot cuaght in the housing below where the lint filter fits,rubbing on the blower wheel.
I hope this helps,
Gene
Aug 04, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Change drier belt on model number 41794702300 Kenmore stackable
1. UNPLUG UNIT. 2. On the front of the unit, remove two screws from the bottom panel. Remove it and you will see two screws holding the top panel and door in place. 3. Remove the screws and gently pull up and out on the door panel, INSURE NOT TO PULL ON THE WIRES LEADING TO THE DOOR SWITCH. 4. Remove wires from door switch. MAKE SURE TO NOTE WHICH WIRES CONNECT TO WHICH TAB. 5. Set door aside and you will have complete access to drum. Remove old belt, if necessary, noting now it is around the drum and weaved through or around the tension bar below the drum. 6. Once removed, or if there is no belt, or a broken belt, put the new belt around the drum so that the slack hangs below the drum. NOTE: You will probably see a black mark around the drum where the belt has laid, about in the middle of the drum. Lay the belt on that path. 6A. Lay on your back with both hands available, raise drum slightly to get access to the belt. Take slack in belt, raise tension bar slightly out of the way, bring belt UNDER the pulley on tension bar and put it around the pulley/spindle on the motor. (This may take another hand) Slowly lower tension bar back down to make contact with belt, applying tension to belt. 7. Get the door panel and reconnect the door switch. 8. Start to put door panel in place, while slightly raising drum to fit into position, careful to the raise to high or **** drum out of position off the back rollers or cause belt to slip off. Push door panel into place and put screws in. 9. Once you've got the door secure, test the belt by reaching inside and manually turning the drum clockwise until it seems to turn easily with not bumps. This is allowing the belt to settle into place and insuring it is not going to pop off; if it does, repeat the operation. If it turns easily, move on to... 10. Replace lower panel. 11. Plug in unit and test to insure drum moves freely. If not, you may need to readjust the way the door panel fits in place with the drum, or the belt on the tension bar. 12. If you need further help, please let me know.
Good luck. It's simpler than it sounds. G
Aug 02, 2010 | Kenmore 77062 Gas Dryer
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
KENMORE SERIES 80 DRYER..The Tensioner use it or not and how?
To fit the new belt, you will need the idler pulley (tensioner)...
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side. Once the belt is pulled through the idler pulley, pull it around the motor pulley (this should force the idler pulley to "open up" and add tension).
If you still need help, I will try to provide you with a diagram shortly.
Mar 02, 2009 | Kenmore 62622 Electric Dryer
Handbrake problem
hi fro uk when you reassembled brake shoes? did you notice the tubular bar just below b/cylinder? it fits between the two shoes and has a toothed wheel on the treaded side(l/h) this is the auto adjuster ie as tooth wheel is rotated it extends the treaded side thus adjusting shoes to drum o/k? this is normally done auto by the small lever below but when fitting new shoes you must adjust this rod with tooth wheel and keep trying drum fitting when you can fit drum /just? fit and press brake to centralise shoes to drum then adjust again if req'd so that drum fits and rotates withh shoes not binding ?? do both sides THENyou willdrums fitted you will feel b/pedal is improved ie less travel on braking ? SO FIRST THING YOU HAVE TO DO IS SLACKEN OFF H/BRAKE CABLE ADJUSTMENT /SLACK ? then proceed with the above instruction afterwards if you do as above then you pull h/brake up one notch ? then adust slack from cable to light tension release h/brake and ensure wheels rotate freely when you apply h/brake it should hold on approx four//five notch ? hope this helps
Feb 04, 2009 | Hyundai Motor 1998 Accent
Fitting the belt to the hoover 5050ed
nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Oct 01, 2008 | Whirlpool LER4634J Electric Dryer
How to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Aug 29, 2008 | Dryers
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Open Questions:
My Kenmore 80 series dryer (64852) develops a buzzing sound while drying. Functionally it works just fine. However, after about 20min (this varies) of run time the dryer will usually begin to buzz. The buzzing seems to come and go for a short while and then becomes more constant. Then about 10min (give or take) before the dryer shuts off, the buzzing usually stops. It doesn't seem to matter what setting the dryer in on. (e.g. "Timed Dry", "Automatic Moisture Sensing") Often times when the dryer begins buzzing I can turn the dial back a bit and the buzzing usually stop for a short time. But it seems to pick up with the buzzing again before the dial reaches the same point where it began the first time. Also, because the buzzing remains fairly constant, and I get the impression that the thermostat is cycling things off and on like it should, I don't really think that this is an issue related to the heating element. Although I've been known to be wrong before. As far as I can tell it does have something to do with heat though, because the buzzing only seems to start after the machine has had time to run and warm up for a while and then stops during the last 10min when I assume the machine would be cooling down. Also, I keep the "End of Cycle Signal" in the OFF position all the time. When I have turned it on in the past it sounds distinctly different from the noise it make while drying. One more thing. The buzzing doesn't sound like vibrating parts to me. Thanks for any help you can give.
Oct 30, 2010 | Kenmore 64852 Electric Dryer
Kenmore 64852 Electric Dryer Logo
359 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
