Question about Stihl Ts 410 420 Cut Off Saw Decompression Grommet
Ts410 wont prime - Stihl Ts 410 420 Cut Off Saw Decompression Grommet
  • 45 Answers
Poss kink in fuel pipe that comes from fuel tank to carb/ primer
Posted on Oct 22, 2014
    New Friend:
  • 4 Answers
Air leak in fuel system \ one of the pipes blocked (the return pipe that goes back to the tank) or pipes on wrong
Posted on Jun 19, 2014
Primer wont prime
put a new primer bulb on it if the old one is cracked it wont prime.
May 02, 2016 | Garden
Stihl saw cuts out when machine is tilted forward on ts410 anybody else have this problem
Fuel pick up will be your problem. Buy new fuel filter and fuel line from in tank to carby. Most likely a split in the fuel line in-tank
Feb 13, 2014 | Stihl Ts410 Ts420 Cut Off Saw Piston Kit...
Stihl Ts410 hard to start and erratic running
http://www.mediafire.com/download/dk8dipzr69pksrk
I've added the breakdown manual for you, have you replaced the fuel and air filters. could be a simple issue of not being able to draw up the fuel from the tank. Stone saws deal with a lot of dust and this seriously effects their running and also their cooling capabilities.
Jan 31, 2014 | Stihl Saws
Starting ts410
This might be an ignition problem... Try setting in new fuel if that doesn't work take it to the shop.
Nov 21, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
12ht wont prime
filling the filters before installing will make priming go more quickly.
once the pump is primed crack open the fuse line at the injector while cranking until you have fuel pulsing out, close it then move on to the next injector.
keep doing this until the engine runs smoothly.
it may start running before all the injectors have been purged so keep clear of all moving parts and a fire extinguisher handy would be a good idea.
Apr 14, 2013 | 1989 Toyota Land Cruiser
Ts410 stihl saw stopped working
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Mar 31, 2013 | Stihl Ts410 & Ts420 Cylinder & Piston Kit
My quantum xts 50 after priming wont fire
does it start when you prime it or does it not start at all? if you prime it and it runs until the prime burns off then won't start again, try priming it again. If it starts and runs until the prime burns off again then it is a carburetor issue. It isn't supplying the engine with fuel to run after the prime is gone
Jan 20, 2013 | Garden
2006 monte carlo wont start without priming
sounds like your fuel pump weak, need to check fuel pressure when engine won;t start and check with engine running
Sep 03, 2012 | 2006 Chevrolet Monte Carlo
Stihl ts410 wont take high revs
after some use the screen inside the muffler gets plugged with carbon and blocks the exhaust flow try and run it with out the muffler they are made to open to clean the screen off
Aug 02, 2012 | Garden
When fitting coil pack on my stihl ts410 what size gap do you leave?
The thickness of a stangard business card. .010-.015
get a free manual from a Stihl dealer like www.arcolawn.com
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Stihl Ts 410 420  Cut Off Saw Decompression Grommet Logo
421 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
rlev_7
Level 1 Expert
Spud Howell
Are you a Stihl Saw Expert? Answer questions, earn points and help others
