Question about Grilling
How do you start a gas grill - Grilling
I just purchased a pre-assembled E-310 Weber gas grill from Home Depot. Upon Start up I noticed the flame is very high on each burner (three to 5 inches above the deflectors on high). Also, I notice n
Hey Anon..
WOA...compressed propane is not something to mess around with..I would go back to the Home Depot and talk to the store manager,,(take your receipt and all other paper work for proof), ask him who to see about your issue.. tell him you are afraid to use your NEW grill.(Start at the top!).. you spent good $$$$ and you deserve an answer..or a new grill..
Sep 11, 2017 | Weber Genesis E-310 Gas Grill
After replacing LP tank, will not start - I don't even hear the gas.
turn off gas on tank open gas burners , turn off gas burners turn on tanl slowly should work now .
Aug 23, 2012 | Weber Genesis Silver B Grill
Grill slow to start, doesn't get hot
sometimes spider webs clogs the orifaces. also check your regulator .if its not making any sound give it a light tap with wooden hammer handle sometimes the diaphram sticks
Feb 24, 2012 | Viking VGIQ5323RE1N Gas Grill
Grill was moved slightly. Now won't start.
Motion sensor inside spiffy new fangled gas bottle tripped. Shut off the gas and remove the bottle.
Open all gas control valves on the the grill and close them all making sure they are all off. Reconnect the Grill to the gas bottle and crack open the gas slowly about a quarter turn only. Light that puppy and party on.
May 08, 2011 | Weber Summit S-670 Gas Grill
New natural gas grill will not start. What are we doing wrong?
Is the inline gas shut shutoff valve, that's required by code, turned ON? Are you sure you're getting any gas to the grill? Have you tried to match light one burner to test it? That's where you need to start your trouble shooting.
Also, don't go by what it said on the box it came in. Check the manufacturer's tag on the grill to make sure it is in fact, a Natural Gas Grill. If it's propane, nothing you do will get it to light. Sometimes the wrong things get in the wrong boxes.
Mar 08, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
Webber grill burners will not go beyond just starting and I used it a week ago and no problem. I put a new gas tank on and the same. Genesis silver unit
This should fixya up.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
Your grill should now heat normally
Nov 10, 2010 | Weber Genesis Silver B Grill
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
