Question about iSymphony 40" 1080p LCD TV
It my first time using hdmi cords. When I turn tv on after about 5 minutes my screen turn s pink and green then restarts only to repeat the same thing
Picture turned green, then went all pink????
It sounds that there is loose solder terminals to the terminals of Chroma IC. Re solder all the terminals by applying a little more solder to each terminal. In practice, it will be very difficult to detect these type of loose solder points. The only way, is to re solder all of them at one time.
Oct 16, 2012 | Toshiba CZ36T31 36" TV
Why is my TV screen PINK?
Have heard of this issue,in most cases while using HDMI cable.Try switching to component cable hookup.(Red/Blue/Green RCA type plugs).This will still give you Hi-Def.(don't forget to get a Red/White cord set for the audio also,unless you get a 5-way cord that does both).
Jun 03, 2012 | Sony Televison & Video
The picture and audio keeps going in and out and HDMI keeps popping up on my screen. Is this the tv or the cable box or maybe the cord?
it could be a combination of things but here is a simple fix
unplug power from both the TV and Cable Box for at least 5 minutes
flip the HDMI cord wait 1 minute plug power cords back in
ENJOY
Dec 03, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
Does the Samsung PN58B650 need a minute to warm up the first time you turn it on every day? When I turn on the TV for the first time every day, the picture is there but the colors on the screen are pink...
I swapped out the HDMI cable with standard component cables. The picture and sound is perfect. Later I will swap again with a different HDMI cable to confirm if the problem is a bad cable or if the TV has a problem with HDMI.
Sep 22, 2009 | Samsung PN58B650 TV
Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Jan 10, 2009 | Toshiba 50HP66 50 in. Plasma Television
Why does the screen turn green when i hook hdmi cord up
I had the same problem.... Occasionally when I changed stations, the screen went totally green.
What fixed the problem was to NOT use a HDMI cord at all! Instead I got a cord made up of five separate "prong" cords (like we use to hook up the old VCR's with ), all with different color-coded prongs that individually get inserted into the corresponding colored holes in the back of the Cable box and into the TV. I got this special cord from my cable company Comcast.
Dec 14, 2008 | Televison & Video
Pink display
It seems the DV-S5950 has an incompatability with HDMI through Samsung TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs...
Nov 26, 2007 | Yamaha DV-S5950 DVD Player
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
PINK/GREEN SHADOWS, LINES
Here is what I was able to find out about your problem from sony: This issue is usually caused by some type of nearby magnetic interference, such as unshielded stereo speakers placed too close to the TV. These spots can be small or large and will normally be red, green or blue, but sometimes appear purple or pink. They normally occur on the sides or corners of the screen, but can also appear in the middle. To resolve this issue, move any stereo speakers or other electronic devices away from the TV; a minimum of 2-3 feet is recommended. If the situation is not remedied immediately, unplug the power cord of the TV from the electrical outlet for 20-30 minutes; repeat this process one more time if the issue is not resolved the first time. If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer in your area. Hope this is helpful:)
Sep 04, 2007 | Sony KP-57HW40 57" Rear Projection...
iSymphony 40" 1080p LCD TV Logo
14 people viewed this question
Top iSymphony Televison & Video Experts
Electro Med Services...
ray gallant
Are you an iSymphony Televison and Video Expert? Answer questions, earn points and help others
