Back to:
Tags:
Rival 38651-C 6-Quart
Rival 28651-C 6-Quart Crock Pot
posted by PotinMexico on Nov 04, 2007
Dear Problem Solvers:
My Rival crock pot boils on all settings. My question is there some way to reduce the temperature settings on this product? By that I mean a place on the product where I could turn a screw, a setting device, or make a wish over it at midnight and the temperatures could be adjusted so that the settings reflect reality or must I accept the reality of the pot and ignore the fact that the pot boils at all settings.
A crock pot owner in Mexico
Comment by PotinMexico, posted on Nov 09, 2007
Dear Moryath,
Thank you for the information. I am in central Mexico at 7,500 feet above sea level.
Sincerely,
PotinMexico
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
Moryath
Rank:Master Master
Rating: 85%, 39 votes
There seems to be an ongoing question about this unit - many of them are reported as attaining high temperatures. There is no way (short of actually replacing the heating element) to alter the temperature of the unit.
Additionally, you state you are in Mexico - are you in Mexico City or somewhere else? You have to remember that "boiling" actually takes place at different temperatures based on air pressure, and at the pressure in the altitude of Mexico City (11 psia) water will boil at a mere 189 degrees, which is not far off of the 185 degree "target" that they are designed at to be sure that the cooker kills bacteria.
Comment by Moryath, posted on Nov 09, 2007
Dear Pot,
You're welcome - and if you're at 7,500 feet (which would indicate a that does appear to be part of the "issue" with your slow cooker.
The good news is, this shouldn't harm your foods in any way. The slow cooker is a relatively closed system, so the vast majority of steam generated should condense back on the lid and return to the broth. Just make sure you're careful opening it up to avoid scalding yourself.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Rival 28651-C 6-Quart Crock Pot:
I don't want to Accept this solution
Can you Help with these Crock Pots and Slow Cookers problems?
I have a Rival model 3865 crock pot. How big is it?...
I have a broken crock on my Corningware Electrics SC0-200....
Has anyone with this crock pot had the problem of not...
I recently bought a set of 4 stoneware that was designed...
I just plugged in the crockpot and all of the red lights...
Loading problems.
Repair Service
Find Crock Pot and Slo. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
