Question about Acer Ax1930 -ur30p Desktop Pc, Intel G620 Dual Core, 4gb, 750gb 7200rpm, Hdmi
Where us the audio jack?
My speakers won't play sound because they're plugged in through the audio manager jack. Where is the speaker jack?
  • 44 Answers
SOURCE: No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Posted on Sep 17, 2007
  • 279 Answers
SOURCE: Connecting 4 speakers
The microphone jack won't help you at all. It only accepts incoming sound, it doesn't play anything back.
The problem with using the headphone jack is that it puts out more current, since headphones aren't usually self powered. It's generally not good for the speakers to use the headphone jack for them.
And as your speakers did not all come as a single set, it's unlikely either set has output ports designed to plug additional speakers in.
So what you need is the stereo mini jack splitter, as electroguy mentioned. In case you don't know what we mean by that, here are a couple links to sites with two different versions:
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=149749
http://www.dv247.com/invt/13646/
However, you probably can save money by buying it locally. For small items like that, shipping kills any savings you have online. I know Radio Shack sells them, but it's likely you can get them at any store that sells stereo equipment.
Once you have the splitter, just plug it in to the back of your computer, where your speakers are currently plugged in, and plug each set of speakers into one of the two ports on the splitter.
Hope that explains everything clearly.
-Dyllan
Posted on Dec 17, 2007
  • 59 Answers
SOURCE: Headphone Jack Problem
Go to the icon tray and double click the speaker icon. Have a look in the Advanced controls to see if you have taken the mute off the pc speaker. There might also be an option to play sound on the pc speaker simultaneously with the headphones. If so, uncheck the dual play box so the sound will not play through the pc speaker when you have the headphones plugged in.
Posted on Aug 06, 2009
SOURCE: subwoofer won't work plugged into Acer laptop
i have an aspire acer 5735z laptop in the manuels it says its possible to have a video confrence,but when using msn messenger it says no webcam has been installed..how do i find or locate the webcam,if their is one at all?
Posted on Sep 01, 2009
  • 59 Answers
SOURCE: Acer Aspire 5720 sound not working
that means the guy or someone who replace the new harddrive didn't to a good job on restiall a new window vista for you, just simply go acer.com and search your model, redownload the sound card driver.
that's it.................
must be sound card driver problem.
Posted on Dec 29, 2009
Jbl speakers turn off on their own
Sounds like you have them plugged into the wrong jack
Jan 01, 2013 | JBL Jembe Two-piece Entertainment Speakers
Suddenly no sound from speakers
First, we must determine if the problem is with the speakers themselves, or with hardware or software of the computer. Try plugging a set of headphones into the audio out jack of your system (often times, this will be a green colored jack). Play sound on the computer while listening to the headphones, can you hear the sound? If so, the problem is with the speakers, otherwise, you need to troubleshoot software/hardware of the system. Another method would be to try plugging these speakers into the headphone jack on an mp3 player, mobile cd player, stereo, or similar device. Aside from the system not putting out sound, the speakers could be plugged into the incorrect jack on the system (not audio out, OR not audio out on the correct device), or turned all the way down.
Sep 18, 2011 | Dell A215 Computer Speakers
My speakers won't play any sounds when hooked up to the computer. I hooked it up to my ipod and it played
im not sure i understand what won't means????????
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 18, 2011 | MidiLand MLi 691PA Computer Speakers
Keep getting "just plugged in audio jack". Sound
Hi, You r suffering it because it may be that speaker is not correctly plugged in or your speaker's lead is damaged.
Jan 27, 2011 | ASUS M2N-MX Motherboard
We brought some Sony SRS-D21 speakers for our pc yesterday but there is no sound coming through them when plugged into the rear jacks on the pc. We have test sound when plugged into the headphones jack at...
control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 05, 2010 | Sony SRS-D21 Computer Speakers
No sound from built in speakers HP VS 17. Device is working properly when i checked the device manager and i can see the speaker icon in the taskbard. was working before i shifted the desktop to a new...
Try using MP3 player feeding the monitor to see if you get the sound OK first. Are you using stereo male to male mini jack for connection from PC audio line out (Green jack) to Monitor audio line in (Green jack)?
Feb 27, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Need 5.1 not 2.1
Easy dear! Go to ur sound manager/ audio input output tab\ set ur speakers from 2 speakers to 6 channel speaker... Now perform test. U will hear sounds from every speaker.
Note: Ur sound manager is on ur system tray found near ur desktop clock... a brown colour most of the time
Feb 06, 2010 | Logitech X-530 Computer Speakers
Windows 7 cant hear 5.1 surround sound through laptop audio jack
Are you sure that the soundcard supports 5.1 on your laptop?
Dec 13, 2009 | Computers & Internet
I HAVE NO SOUND ON MY GATEWAY GT5660E. i HAVE TRIED EVERYTHING
Do you have the speakers plugged into the correct plugs in the sound card? Make sure speakers are not plugged into the mike jack. Do you hear any static as you remove and replug the jacks? Do the speakers have a power light?
Open Control Panel ->Sounds and click on Sounds tab. Do any sounds play? Click on the Audio tab and make sure Default device is your sound card. Click on Volume tab and then Advanced. Make sure nothing is muted.
Assuming you have Windows, check the sound card in Control Panel->System, Hardware, Device Manager. Check for correct drivers. If necessary, uninstall sound card and let Windows detect it again and install drivers.
Sep 16, 2008 | Audio Players & Recorders
Acer Ax1930 -ur30p Desktop Pc, Intel G620 Dual Core, 4gb, 750gb 7200rpm, Hdmi Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
