Question about Hifonics Car Audio & Video
Hifonics bx2200 diagram - Hifonics Car Audio & Video
Bridging hifonics vii
find the minimum impedance supported by your amp so you dont burn it up.
look here.
http://www.the12volt.com/caraudio/boxcalcs.asp
Oct 14, 2013 | Car Audio & Video
Im looking for a company that sales hifonics samson xi line input that broke of my amp..
Hifonics is sold by Maxxsonics
http://www.maxxsonics.com/hifonics/
You can contact them at support@maxxsonics.com
Feb 28, 2011 | Hifonics Generation XI Thor Car Audio...
Wire diagram for hifonics triton eq
well their are 3 outputs if they have been rewired. Don't worry it will say acc+,ground,remote.just look it at edge of your equalizer.
Jan 05, 2010 | Hifonics HFEQ Car Equalizer
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
Sep 07, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
Acquired a Kubota BX2200 with house. How do I start it?
What??? I have a BX2200, there is no choke or clutch??? The deck can be in any position????
Check:
1. Make sure it is on Neutral.
2. Make sure the PTO is disengaged.
3. Turn the key until the orange (glow plug) light comes on and count to five, then start.
Is is turning over and not starting, or doing nothing.
Send me a PM.
Dan
Mar 06, 2009 | Garden
Hifonics Taurus circuit diagra???
You need to measure the voltages at the output transistors. The previous "driver" stage may have a problem. These outputs use .6V as the bias differential. Check for DC voltage on the inputs to the transistors. These are standard designs. I'd check for DC anywhere along the signal path.
Dan
Apr 09, 2008 | Hifonics Brutus BX 1505D Car Audio...
My bx2200 cut off as soon as it was turned on and started smoking?
It sounds like the power supply transistors have failed. You'll need to pull the clamps and get the numbers off of the transistors. It's also possible that the 47 ohm gate resistors have failed. After removing the old transistors, you need to check the resistors individually.
Since you're new to repair work, read the following page.
Basic Repair Introduction
Post the part numbers if they are incomplete and you can't find the correct replacements. mouser.com is probably the best place to buy small quantities if you're in the US.
You also need to check the output transistors to see if any are shorted. If they are, the repair will be more difficult (especially if there is damage to the driver board).
Feb 15, 2008 | Hifonics Brutus BX 1605D Car Audio...
these are the trasistors..The ones closest to the power connectors are probably the ones for power supply and or 15 volt regulators..The rest are for amplifier section.Im guessing all except regulatos will be MOSFET transistors .If you are to replace them ..Stick to original parts..You can probably find these at mcmelectronics.com or mouserelectronics.com Just give then the numbers on transistors .Also make sure all other parts around shorted parts are okay before you install new parts..
Dec 09, 2007 | Hifonics BX2200D Car Audio Amplifier
Car Audio & Video Logo
47 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
