Question about B&K Plumbing
Water is not coming out of faucet - B&K Plumbing
    New Friend:
    Problem Solver:
  • 9 Answers
Is this an old faucet or newly installed? If old, trace the issue back to the blockage, if new, be sure the supply line valves are open beneath sink.
Posted on May 12, 2014
How do I clear the hose that goes through the faucet? Water doesn't come out of faucet.
  • Get a bucket.
  • Go under the counter. You'll see some shut-offs. Close those.
  • Disconnect the lines -after- the shutoffs that go to the faucet.
  • Some water will drip out of the lines -- catch that with the bucket.
  • SLOOWWWWLY open the shut offs. WATER WILL COME OUT. A LOT OF WATER. Catch it with the bucket. You just need to crack them a little.
  • When water is clear, put it back together.
If that doesn't work, then you may need to clean or replace the cartridge. Those directions depend on the type of faucet. Google "cartridge removal" and the brand/type of faucet for more details.
May 04, 2016 | Plumbing
How to replace a sink faucet
Shut the water off to the faucet. Open faucets above this unit to allow water to empty in the pipes.
Disconnect the water supply from the faucet.
Unbolt the faucet from the counter top.
Didn't the faucet come with directions?
Aug 11, 2014 | Kohler Plumbing
Moen kitchen faucet
Hi Steve-If the faucet is definitely getting water (making sure all the cut-off valves are open along the way), the Moen single handle faucets all use a replaceable cartridge that is available at home supply stores. This cartridge is what regulates the pressure and the temperature of the water coming out of your faucet. This is likely faulty. You'll need to close the supply valves (hot and cold) underneath your sink prior to replacing.
Apr 01, 2014 | Plumbing
No water coming out hot water faucets cold is fine.
First check to see if the main faucet to your hot water system is turned on. It could be someone has closed it. It is located around the bottom of your system. If that is open, water should be entering the tap.. To check this shut the main faucet at your water system and using a wrench loosen the connection from the faucet to the system and slowly open the faucet to see water comes out.. If it does that means the main water serivce to the system is fine .. You can also check this at the system by gently opening the outlet connection which should be at the top of the system , ensure that the main faucet At the bottom of the system is closed, once the connection at the top has been loosened slowly open the faucet to see if water comes out of the outlet.. If it does then the problem is from the system to your household faucets.. Could be a crushed water line . Also check to see if your hot water faucet is not Jammed. Sometimes the rubber inside the hot water faucet could be blocking the water if the faucet has been recently over tightened when closed.. Hope all goes well
Jun 04, 2013 | Kitchen Ranges
Rusty water comes out of cold water faucet
Rust is usually a sign of galvanized pipe mixed with copper pipe incorrectly.Could be the pipe nipple used for the tub spout connection to the valve.You could change it to a brass nipple might be the problem
Jun 24, 2010 | Moen 1 Handle Lever Shower Faucet With...
Water not coming through faucet - does come through side spray
First check the aerator at the tip of the faucet where water comes out. Unscrew to check for blockage. If water still does not run, most likely a problem in the body of the faucet. Is faucet still under warranty? If you try taking the faucet apart remember to turn off the water supply lines at the angle/strait stops under the sink. Recommend replacing faucet.
Mar 16, 2010 | Price Pfister 042-HAK Amherst Single...
Turn hot handle on - water does not come out of faucet
is the feed on the bottom of the sink open . if it is shut the water off from the bottom and take apart the handle to see if something is stuck in there
Sep 26, 2009 | Moen 4551___ Monticello Popular Two Handle...
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
44 people viewed this question
Top B&K Plumbing Experts
Tom Chichester
Bill Boyd
Daryl Gleaton
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
