Question about SanDisk Sansa c200 MP3 Player
SP? Same Problem... Press power and the battery shows up on the screen saying its dead buts its been charging ??
My SanDisk Sansa c200 is froze on the start up screen HELP ME
Posted on Jul 23, 2009
My proline tablet H71930i will not charge or be turned off. The indicator that the battery needs recharge when off does not show....please help it worked this morning but now it's dead.
do a hard reset and then make sure the software is up todate. 1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
Jan 15, 2018 | Tablets & eReaders
Tip
How do I find if my iPod touch battery is dead?
<p>When the iPod touch battery dies, you cannot do anything with the device. You will receive a warning on the screen of the iPod touch, when 5 percent of the battery turns on the device. Connect the device to a power source as soon as possible to load and prevent the battery goes dead. When the battery dies, the unit will shut down and will be connected to a power and charged before you can use <br /> <p><br /> <p>1. Press the iPod touch "Sleep / Wake" button, located along the upper side of the machine. If your iPod does not care, this is an indicator that the battery is dead. <br /> <p><br /> <p>2. Connect a charging cable to charge your iPod and connect the USB cable to a power of high power. High-power USB ports directly on your computer tower or, if the hardware usually found in the tower on the monitor, the monitor itself. The iPod touch screen shows a big red battery icon on the far left of the icon, indicating that the battery was empty. <br /> <p><br /> <p>3. Press the "Sleep / Wake" to see if the iPod is connected. If so, check the battery life, looking at the battery icon in the upper right corner of the screen. When the icon appears white, the battery is full when the icon is half black, the battery is almost dead, and if the battery is almost dead, you will receive a warning. If the iPod does not start, the battery is completely dead. In this case, your iPod into electronics store and have the battery replaced. <br />
on Aug 05, 2011 | Computers & Internet
Service support helpline in hyderabad hp
If your saying that the battery is blinking. In my opinion it sounds like it could be a dc jack charging issue. Lets first start with doing a hard reset of your device. Hold down the power button for 30 seconds without the charger plugged in. Then reconnect the charger and try powering the device on. Try to identify if there is a pattern in which the battery LED is blinking. Does it just consistantly flash, Or do you notice it blink three times and then pause. We can try to troubleshoot this further if you have any issues after gathering this information.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matthew_7a3ed9e055c167c4
Sep 25, 2017 | HP Computers & Internet
Screen has hp logo and says press the ESC key for startup menu, but is not responding
Try a hard reset. Disconnect the power adapter (charger). Remove the battery. Now press few times the power button. Yes, with no power the laptop will not start but the idea is to drain any residual power left inside your laptop. Put the battery back and try again.
Dec 15, 2013 | HP ProBook 4530s Notebook
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
Toshiba SP 6100 Battery problem
If the charge light shows a blinking amber, then the battery is dead. If the charge light shows a solid amber, then it's charging.
Which is it?
Dec 31, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Dell Inspiron 1501
sounds like a dead cell in battery try replacment battery batterys can still show good even if they have a dead cell
May 31, 2008 | Dell Inspiron 1501 Notebook
SanDisk Sansa  c200 MP3 Player Logo
93 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
