Question about Frigidaire FAFW3801LW Washer
Reverse the door frigidaire fafw3801lw - Frigidaire FAFW3801LW Washer
Reset a fridgadaire front loader washer
Thank you for your inquiry, Cynthia!
From what you have described your Frigidaire washer will not drain. I would recommend checking the drain hose to make sure it is not too long or restricted. If the drain hose checks out it could be a possible problem with your drain pump or motor. To perform a reset on your washer you need to disconnect power from it for at least ten minutes. If that does not help correct your issue you may need to seek assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Aug 03, 2015 | Frigidaire FAFW3801LW Front Load Washer...
How do I change out the door seal on a frigidaire affinity washer model fafw3801lw
Thank you for your inquiry, Tina jackson!
From my understanding you need to change the seal on the door of your Frigidaire washer. The seal can be held onto with the washer by a clamp or spring. I have been unable to locate a step by step instruction sheet on how to remove the seal. This job may require the assistance of a professional technician. If you do not have a professional connection you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! -Matt
Feb 08, 2015 | Frigidaire Washing Machines
HOW DO I REVERS THE DOOR
Hello friend, thank you for your post!
I understand that you are looking to reverse your doors on your Frigidaire dryer. I have located the installation instructions and on page 7 and 8 it explains the process of door reversal. I hope this helps. -Matt
Frigidaire Manual Search Results
Sep 20, 2014 | Frigidaire Dryers
Reverse door
Good morning friend, I appreciate your post!
I see you are trying to reverse the door for your Frigidaire top mount refrigerator, FFHT2117PS. I have successfully located your manual and it provides step by step instructions on how to reverse your doors. Hope this helps. -Matt
Jul 23, 2014 | Frigidaire FFHT2117PS 21 Cu. Ft. Top...
How to remove Frigidaire water vane?
Good Morning Friend,
I understand you want to know how to remove the water vane on your Frigidaire Affinity washer, model# FAFW3801LW. I see that there is possibly a penny inside the vane that you can hear an feel as the drum rotates. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to take the vane off and remove the penny with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Affinity FAFW3801LW 27"...
What is making my Frigidaire Affinity Washer FAFW3801LW fill and start working and then after 2 minutes there is an ugly noise and it displays "pause"?
Good Morning Doina,
I understand your Frigidaire Affinity washer, model# FAFW3801LW, will fill and start working. I also see that after about 2 minutes, you hear an ugly noise and your appliance displays "pause". I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FAFW3801LW Washer
Frigidaire stuck pump
PROPELLER OBSTRUCTION? REMOVE AND HAVE A CLOSE LOOK AT IT U MAY BE ABLE TO REMOVE WHATEVER ITEMS IS PLUGGING IT
Apr 21, 2014 | Frigidaire FAFW3801LW Front Load Washer...
Washer door latch broke
Many of these are made of plastic, or plastic and metal. Looking at a new one, you will see they are made most cheaply. You may buy a new one at "Sears Parts" on your computer, or, if you will enter your model number, they will tell you the part number, which you may choose to order from "e-bay". You will need to take the front of the machine apart to replace this part.
Be blessed.
Jan 31, 2014 | Frigidaire Fafw3801lw Affinity 3.26 Cu....
FAFW3801LW3 has error e59
Hi Rosie,
I understand that you're receiving an E59 error code on your Frigidaire washer, model# FAFW3801LW3 and are looking how to run the diagnostic test. While there isn't too much information about actually running the diagnosis, I would recommend contacting the manufacturer and seeing if they are able to assist.
-Best Regards-
Jan 23, 2014 | Frigidaire FAFW3801LW Front Load Washer...
My frontloader was in the last cycle when it started making a loud grinding\ or something stuck between the drum kind of noise i shut it off took the clothes out and ran another cycle empty and the noise...
when wou stoper the washer the thing that was stuck between the drum was abel to get to the drane at the bottom of the drum and is probley cout in the cach pan unred the durm remove frunt cover and look for a removeable pluge to find the obiject.
Mar 19, 2013 | Frigidaire FAFW3801LW Front Load Washer...
Frigidaire FAFW3801LW Washer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
