Question about Briggs & Stratton Garden
Why briggs and stratton pro series, 27 hp, model 44Q777 & won't start?
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 376 Answers
SOURCE: what is the valve clearance on a briggs &
.003-.005 intake, .005-.007 exhaust for single cylinder OHV
Posted on Jun 14, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Posted on Sep 30, 2009
eazyduzit
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
I had the same problem and thought my starter was bad, I got some advise from a friend that i should try adjusting the valves, I did that and mine starts fine now. hopefully this helps you
Posted on Oct 06, 2012
We have a 27hp v twin briggs & strattion which back fires and surges when engine is hot
have you tried checking the lean,rich needle on the carb sounds like it's to lean. good luck
Aug 11, 2014 | Briggs AND Stratton Intek Briggs &...
Act like it is flooding out at high rpm
try cleaning the air filter as it is probably blocked
Jul 13, 2014 | Briggs AND Stratton Intek Briggs &...
Manual choke
no it probably has automatic choke to work
May 03, 2014 | Briggs & Stratton 44Q777-3136-G5 724cc...
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a Murray snowthrower Pro series 27'' 10.0 HP. After 1 hr of grating noise (like bearing) it stopped throwing.
So many things,
You need to have someone with eyes on for this one.
As it could also be a catastrophic problem.
This engine also has a history of bending push rods.
Hope this tips helps.
r/
David
Dec 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Want a repair manual for a 17 hp briggs & stratton engine
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Oct 01, 2009 | Garden
Garden Logo
14 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
