Question about Electric Mobility Health & Beauty
Mastech my68 do i use a 24v charger for my scooter.on the motor it says 24v 6a output 100w and rated speed 2500rpm
E scooter my68
My scooter slows down then goes back up again
The problem you have got is the throttle pot is faulty. Get this replaced and it will be fine
Jun 19, 2015 | Pride Mobility Products Celebrity X...
How to speed up SHOPRIDER WISPA scooter from 4mph to 6 mph
hi, that's not possible, the controller and motor does not have the capacity to do 6 mph,( Controller output + motor wattage ) and the scooter would not feel that stable at higher speeds.
Regards
Rob
www.gewizrepairs.co.uk
Aug 24, 2014 | Health & Beauty
My pride go go elite traveler 4 wheel stops randomly often with no beeps. I have replaced the throttle, the speed pot, the brake, and the batteries check out fine.
You may have a loose connection at one of the harnesses or connectors. If there are no codes you may have a bad controller or loose connection at the controller. Slow speed problems may be motor or motor brush problems you can diagnose by visual inspection or a voltmeter. Load test the new batteries and the charger output. Block it up and run it checking and knocking all the components until it quits. I have seen a dragging brake caused by a melted controller harness at the controller connector cause a similar problem. Hope this helps.
Aug 18, 2012 | Pride Go Go Elite Traveller Plus HD 4...
What makes a speed pot go bad on a celebrity x 3 wheel scooter?
Yup you got a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pot is a variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should move gracefully up to 30k down to zero as the pot dial scooter speed increases. Failure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 23, 2012 | Pride Health & Beauty
What makes the speed pot go bad on a 3 wheel celebrity x scooter
Yup you gt a code seven failure code, speed pot malfunction . What pots typically do is that they oxidise. This pt is aa variable rersistor that opeates between 0 - 30k ohms. When tuning the pot it shoud ram up and down smoothly. To test for this
Disconnect batteries from the scooter. Simply attach the multimeter to the pots terminals, select correct ohms scale and watch the needle. Th needle when turning the pot should movee gracefully up to 30k down to zero as the pot dial scooter speed increases. Faaailure is detected when the needle jumps around, the oxidation causes the pot to connect inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the pot. The potss are not sealed so there are little holes you can spray into. Use liberal of cleanner.
Jul 23, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
Problem with mobility scooter
Take the batteries down to a battery shop and have them load tested. Make absolutely sure they are DEEP CYCLE batteries. My 35a\h batteries put out 480 cranking amps. The battery shop can also test your charger. I have two chargers for my scooter the 4amp charger that came built into the chair, and a really nice three stage 5amp external charger. My scooters batteries have two 50amp quick disconnect connectors. I made up an external harness for the 5amp charger with the same connectors. I can now charge up my batteries out of the scooter. They say my built in charger is a 4amp charger, its slow in comparison to the 5amp charger. Batteries are expensive, regular chargers charge at one rate, full speed and can overcharge a battery. A three stage charger is by far way batter on your batteries. When you start to charge a depleted battery it put out full 5amps but as the battery nears being charged the charger backs off the amperage. When the battery is fully charged the charger goes into float mode and put out just enough amperage to maintain the charge. When i'm not using my scooter i keep the batteries connected to this charger. Deep cycle glass mat batteries don't stay charged very long when just sitting around. In about six months a dead battery will sulfate to the point where it will no longer take a charge. That happened to me once and cost me $200, never again will this happen to me. Battery shops are great places they have the instruments to tell you everything you need to know about the batteries. The batteries are the heart of your scooter unless you know there condition all kinds of strange things can happen. To make sure my batteries were good i have them checked against a known good set of batteries. BTW- Cranking amp is measured by putting a load on battery and increasing that load until the voltage falls off. At the point just before that voltage drop they measure the amperage output, that is you're cranking amps
Jun 22, 2012 | Electric Mobility Health & Beauty
I have a 1992 Rascal, Model 240. The charger assembly has a burnt mark on it. Is there a schematic or picture of the board that I can get? My brother may be able to fix it, but he can't identif
The charger is a 24v 4 amp one stage device. Its an incredibly cheap charger. It consists of a step down transformer, a bridge rectifier, a filer capacitor, and a voltage regulator. Virtually all chargers are made this way. Generic schematics
http://www.simple-electronics.com/2011/10/24v-battery-charger-simple-and.html
This charger is built around the famous an popular LM317 chip it really simplifies things.
http://www.circuitstoday.com/24v-lead-acid-battery-charger-circu
I would get out my trusty multimeter and chase 24v though the device.
You may need a VOM meter only $9
Set the meter to read VAC, you should get 30VAC out of the transformer. Next check the rectifier section, Set the meter to read VDC, the output should be about 29VDC. There is a fuse in there that you can check out. Then there is the regulator, if any part of that is fried, you're going to have a hard time finding parts. i really miss the 60's when there were electronic stores on every corner. There used to be a time when you could order your your TV as a kit. You could literally teach your kids something useful at the kitchen table. Quite frankly a 2 amp charger cost $14 4 amp cost $28. Not worth fixing really.
Chargers can be found here
http://www.amazon.com/Electric-Scooter-Battery-Charger-Prong/dp/B001GMTKN4
Jun 19, 2012 | Electric Mobility Mobility Electric Power...
I needto replace the battery charger on my Rascal 600F scooter
Hi. Most chargers with only two wires, have a small bridge wire from the
black ( negative ) wire to the middle terminal of the connector. This disables the controller while the machine is charging. The charger will still work without this bridge wire, but the scooter will still operate normally.
There are a few different chargers around that have an internal relay that disables the scooter, but these chargers are normally "on-board" chargers.
Good luck. Neil.
Jul 05, 2010 | Electric Mobility Power Electric Scooter...
The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Jul 11, 2009 | Golden Technologies Avenger 4 Wheel...
Does the S600 and a Missle FS schwinn scooters use same charger?
Hi you can use the charger if the Specifications match up. Output volts, Amps, Charger size, The most important is it 24 volt or 36 volt charger. Check your scooter to see what volt it runs at. Must be equal to your scooter!
Mar 03, 2009 | TitanNet PowerStar Replacement Battery for...
Health & Beauty Logo
53 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
