Question about Acer Notebook
What is the frnch word for "Delete" for computers
How to find a video and delete on a computer
Search for the video's name and delete it. Or... search for all videos saved between ___ and ___ dates and select the correct one from the search results.
Don't get caught. 8)
Aug 12, 2014 | Computers & Internet
Tip
Cant delete computer programes click here!
If you can delete your computer program first delete it from your program from your desktop, then go to all programs and delete it from there then go to remove/ add program and delete it from there. then go to computer, c drive then go to your type of computer then find it in there and delerte it from there that should wipe that unwanted program fully from your hard drive.
on May 15, 2010 | Computers & Internet
Clear the cache
If you want to clear the browser cashe, open Firefox, Chrome, Internet Explorer, etc.
Press Ctrl+Shift+delete keys. Select items you want to delete.
If you want to clear browsing history, open browser, Press Ctrl+Shift+H and history box appears. Open, Highlight and press delete.
If you want to clear cookies and temp files on computer, then search computer for Prefetch, and delete all contents, then search for %temp% and clear the contents that delete. To clear all of %temp% folder, restart computer and repeat delete steps as soon as computer opens fully.
Jun 26, 2012 | Dell Inspiron Mini 10 Notebook
I have a sony DSC-S730. I access it from my computer. Have tried to delete photos but im not able unless i delete manualy from the camera one at a time. Please assist
Computer can not delete pictures in the camera. Computer can delete pictures in the computer. Camera can delete all pictures or format the internal memory?
Dec 14, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Delete key doesn't work
The ". del" key on the Numerick KeyPad will delete if you use the SHIFT key at the same time. It is easier to use the DEL key on the main keypad.
Jul 07, 2010 | Microsoft Computers & Internet
When you delete files is it possible to retrieve them later
Normally, deleted files from the computer can be retrieved later using the Recycle Bin. When you delete something, it doesn't really delete, it marks the file as deleted, but holds onto it until you permenantly delete it. There are a few cases where deleted files can't be retrieved later:
1. If the file is too large for the Recycle Bin, it will prompt you to permenantly delete the file.
2. If the file resides on a network device or a different computer, it will NOT go into the Recycle Bin; it will be permenantly deleted unless the remote computer/device is a server which has a "deleted items retention period" configured.
3. If you delete a file using "Shift + Delete", it will not go to the Recycle Bin; it will be permenantly deleted.
Hope this helps!
Mar 03, 2010 | Network Computing Devices (NSH800S/A)...
Minolta dimage 7i
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DONT FORGET TO RATE;
Oct 10, 2008 | Konica Minolta DiMAGE 7i Digital Camera
What do i need to do to delete the iphone photos ?
2 ways:
1. When you click "import photos" while syncing your iPhone it asks you if you want to keep the originals or delete them (meaning on the iPhone). Just click delete originals
2. Go into your iPhone and clear all photos.
Jun 09, 2008 | Computers & Internet
Uninstalling program from the computer?
  1. Go to Applications 650_app.gif (info).
  2. Open the Menus 650_menu.gif (info).
  3. From the App menu choose Delete.
  4. Tap the name of the application you would like to delete.
  5. Tap on the Delete button. Tap on the Yes button to confirm that you wish to delete the chosen application.
Delete programs from your Z22 by using your Z22 and not your computer
Jun 05, 2008 | Palm Z22 Handheld
I have an ICE2O frnch botton freezer. The ice flapper continues running, with multiple flashing lights, and the water and ice will not dispense
you have a bad HV board in the back easy to replace..
just let me know
you can unplug the despenser at the top of the door until you get a new board
Apr 05, 2008 | Refrigerators
Computers & Internet Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
