Connecting ricoh 161 to coin device - Office Equipment & Supplies
How to enter service mode in ricoh aficio mp 161
Service mode is 'Clear-1-0-7-stop (hold stop until machine goes into service mode).
Aug 22, 2012 | Ricoh Aficio MP 161 Black and White Copier
Sc 335 da Ricoh 1075, como solucionar?
Olá!
Esse erro está relacionado com o Motor Poligonal do Laser.
Antes de mais deves actualizar o firmware da maquina. Existe uma referência que corrige esse sintoma.
Se depois da actualização o problema persistir poderá ser 1 destes problemas (por ordem de solução):
1-Mau contacto nos cabos do Motor Poligonal.
2-Motor Poligonal avariado.
3-Placa IPU avariada.
Espero ter ajudado.
See you!!!
Apr 01, 2011 | Ricoh Office Equipment & Supplies
TENHO UMA RICOH 161 E DEU O CODIGO SC 819
Isso é um erro de firmware.
Existe uma actualização que corrige isso. Se tiveres acesso a descarregar os firmwares e se souberes como fazer... O teu problema está resolvido.
Contudo aconselho que ligues com a assistencia tecnica. Contacta com a Ricoh portugal e eles enviam-te um tecnico que saberá fazer isso.
Boa sorte.
Mar 01, 2011 | Ricoh Aficio MP 161 Black and White Copier
I have a Ricoh Aficio MP 161 that was given me to use at work, I am on a construction site, and we don't have internet access, so I had to borrow a Verison Access card... anyway I have tried to install...
What was the driver that was installed? Where did you get? Are you sure that was installed the PCL6 for Ricoh Aficio MP 161?
I think your problem is with the driver. You can download for free the driver on the page of Ricoh.com.
You have a good equipment. I have much experience in this model. Reply any question ok!!!???
Feb 08, 2011 | Ricoh Aficio MP 161 Black and White Copier
WHAT RICOH PRINTER IS COMPATABLE TO THE RICOH AFRICIO 1515
The 1515 is compatible to the 161 and the 171, the two newer generations of similar printers. All three use the same toner and photoconductor units, and are set up almost identically.
Nov 20, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I am trying to set up my Ricoh mp 161 to scan to my mac...need help.
You may need to purchase the PostScript card to do that, generally the Ricoh's don't comunicate with Macs without it, Your local Ricoh dealer should have a "Print Scan" qualified tech that could help you out. I could try to talk you through it, but I don't think this web site has enough space to type it out.
Oct 02, 2009 | Ricoh Aficio MP 161 Black and White Copier
Conecting it to a coin machine cartadis cm4000
Enter SP mode and select SP5113 - Optional counter type.
Good luck and please rate me, thanks.
Nov 11, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
11 people viewed this question
k24674
