Question about Cooktops
Ceramaspeed 200N8 L5972R
Need new
Need new glass top schott hob
You need to buy the new glass top without the elements, there is no fixing it, or should not be fixed, it should be replaced.
Apr 09, 2013 | Cooktops
I need a dual burner switch for my Amana cooktop model ak2h30hr
Fit two switches. Although this might be as expensive as a new cooktop.
Mar 27, 2010 | Cooktops
Glass top broken need new one
Call Reliable Parts 1-800-666-0313 with your model number and they will ship you one. Good Luck, Appliance Specialists
Dec 30, 2009 | KitchenAid Cooktops
No Longer Available
if you are installing a secondhand gas cooker then you need the manufacturers instructions you need to be a gas engineer and if the parts are no longer available you should get a new unit
Aug 10, 2009 | Cooktops
My jenn-air JEC9530 is red light blinking.
you will need a new heating element in and if that dosent work you need a new one
May 30, 2009 | Jenn-Air JEC9530 Electric Cooktop
Regulater on a new gas cooktop
Use the new one, it usually comes with the cooktop.
Jul 05, 2008 | Cooktops
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
Dacor 46 inch 6 burner cooktop
The cost of the parts you want t o replace will usually exceed the price of a new cooktop.
Jun 08, 2008 | Dacor Preference SGM466 Gas Cooktop
Trying to install a new range top into new counter top
Generally, you only need enough room to be able to install. The instructions with the range top will specify any other requirements.
Jun 08, 2008 | Cooktops
Cooktops Logo
213 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
