Question about Acer Aspire One D255 Netbook
My notebook is struck setup is starting service after a factory reset
2 Suggested Answers
davidgreene
  • 663 Answers
SOURCE: my laptop will not start
If this is the first time that you turn on your laptop after resetting it to the factory settings then don't do anything while setup is starting services because you will just mess up the computer. It's really gonna take time to start the services. It's still in the set up process - it's loading some files on it.
I hope this helps!
David
Posted on Feb 23, 2013
Baird tv struck on standby mode
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jan 18, 2017 | Televison & Video
Need to find a reset button on an insignia 12A10-Rev.A that was struck by lightning after only approximately 4 months of buying TV. It will come on for few seconds but then turns itself off.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 11, 2016 | Insignia Televison & Video
I have 19"dvd combi which goes over to dvd for no reason then goes back to tv. have checked for stuck buttons on remote but seems ok. any ideas?
Check for any strucked button/s at front panel of the TV. If all are found OK. try a reset to this set and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 11, 2015 | Televison & Video
Factory reset
restart the computer HOLD the CTRL OR FN +f2 or ESC depend of your model , mark, and go to BIOS setup select to the restore factory default, and ready.
God bless you
Jul 30, 2013 | Dell Latitude E5420 Notebook
My laptop will not start
I hope this helps!
David
Feb 22, 2013 | Acer Aspire 5750Z-4879 : 2.2GHz Pentium...
How to master reset
Master Reset or Factory Reset
When Factory Reset is performed, the setup value will factory default setting
When initialization starts.
1.Select System Setup from Menu Screen.
2.From the System setup submenu, Set Factory Reset to ON
3.When you exit Menu, The phrase FACTORY RESET Appears on the monitor and
The Initialization starts.{ON/OFF} Use arrows UP-- DOWN & , kEY TO MAKE CHANGES
HOPE THIS HELPS
Oct 18, 2010 | Samsung SMT-190 19" Flat Panel TFT LCD...
How do i restore factory settings
To restore factor settings, press the F2 key during power on to enter the setup menu. You can reset to factory defaults form there.
If you find that you get repeated messages indicating that the CMOS memory is corrupt then you should replace the CMOS battery. Service info here.
Jul 08, 2009 | Acer eMachines 520-2890 Notebook
Keys not sounding
You could try resetting the camera and that will set everything back to original factory defaults. Go into you setup menu and at the bottom is reset. Try that and see if that works. If not you would have to send it in. That camera's old enough it may just be the buttons are worn out.
Sep 10, 2008 | Casio Exilim EX-S600 Digital Camera
Reset
If you mean factory defaults, you do this through the BIOS setup.
During the initial boot, a message should flash on the screen telling you which F key to push to enter Setup.
This is, on most systems, F1 or F2.
The text menu normally shows a selection called Factory Defaults or Auto Setup or similar language.
Aug 19, 2008 | Averatec AV6130HS 20 Notebook
Acer Aspire One D255 Netbook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
