Question about Sony Playstation 3 (PS3) Console
Turning PS3 on problems
When i try to turn on my ps3 it begins to launch, then the light turns orange and then makes 3 beeps an the red light start blinking. What should i do?
  • devcreator Dec 30, 2007
    ps3 it begins to launch, then the light turns orange and then makes 3 beeps ... an the red light start blinking. What should i do?...
    i am from india and sony here does not support it so please help me repair it giving tutorial
  • 709 Answers
You and most all PS3 owners have or will experience this problem. Your Heat Transfer compound is dried up. This to me is a definite Manufacturer Defect. Contact Sony at 1800 345-7669 unless your outside North America. If you know how to get to the heat sinks, I suggest you go there and put some new high quality Heat Transfer compound between your processors and the heat sinks.
Also check your Ribbon cable connections, as I did se where one PS3 owner found his Ribbon cable fromt he Card readers miss inserted. He orrectly inserted it and he was up and running. Now you do need to contact and Get Sony to fix this if you have the required credentials. Do not waste your warranty.
Posted on Nov 07, 2007
Why wont my ps3 turn on
The problem might have to do with a power thing maybe the power switch i mean maybe the power at your home went down and that causes the PS3 to basically be unusable, what i would recomend is to go and make a diagnostic to your playstation, im not sure where but im sure that if you google it you might find cheap places to see whats wrong with your ps3Good luck!! :D
Nov 29, 2011 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
After buying new av cables (all i had was an HD cable), plugging my ps3 into my friends giant old mitsubishi tv, and turning it on, nothing pops up on screen. it flickers like the system is starting up,...
Please try the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 30, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has stopped turning on. The light turns to green, the console begins to start up, then it flashes yellow, beeps and goes to red.
My PS3 had the same problems. I found that if I disconnected the HDMI cable and installed the cable with the 3 phone jacks, Red,Yellow, and White, that it came on and has been playable since. Before that I got the YLOD, red screen display, pressed the on button for 3 beeps and got the reset. That worked for about 30min then went to a blank screen. Gave up and was ready to send it to the shop, but then as a last resort I connected the other cable and it has worked ever since. Must have been in the HDMI cable.
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
When I turn on my PS3, the sony music begins and the orange sony wave screen turns on but it doesn't move on to the menu. I have shut the system af by turning off the button at the back of the PS3, I have...
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
PS 3 Won't turn on blinking light
Are you trying to turn the PS3 on via bluetooth controller? If so, attempted to turn PS3 on from console itself. Sometimes the controller will get out of sync with the system and not allow for turning on remotely.
Sep 14, 2008 | Sony Playstation 3 (PS3) Console
Playstaion 3 beeps and dont come on
Okay try turning on the PS3 using the PS3 controller turn it on and see the red light and use the PS3 controller by pressing the middle button the PS button
Rate my Solution Please
I tried my best.
Apr 29, 2008 | Sony Playstation 3 (PS3) Console
My ps3 system blinks a red light when i try to turn it on
When i turn on my ps3 it makes 3 beeps an the red light start blinking.i call sony they told me to rest it on the back, but that did't work,then they told me let it cool down, but it had been off for a week. I look all over the net but could't find anything, until i found a site that said they could show me how to fix any problem with my ps3. At first i was not so sure about ordering the manual but i did, whats $5 plus i used paypal, but long story short i fix my ps3, i recomend this site i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Oct 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
129 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
