Question about Brother QL-500 Thermal Label Printer
Output file name?
When i try and print i get 'output file name'
Cannot print PDF, pop up asks to print to file and enter an Output File Name
If you have a virtual printer (PDF printer like BullZip, PDFPrint, or something else) maybe it is your default printer and when you chose the option "print" you need to choose the the right printer (in your situation HP Officejet Pro L7780 )
Good luck.
Jul 13, 2012 | HP Officejet Pro L7780 All-In-One InkJet...
I installed a lexmark printer, when i try to print it ask for an output file name. the print to file box is Not checked so it should work, but it doesn't.
Check your PORTS tab in printer properties, USB001 should be your default port.
Sounds like you may have XPSPort set which will try to print to file
Aug 10, 2010 | Computers & Internet
Output file name
i installed a lexmark printer and when i try to print it ask for an output file name. and the print to file box is not checked..which would mess it up if it was checked.
Mar 04, 2010 | Lexmark T644 Laser Printer
Cannot print a pdf
Are you using Adobe Writer, try un installing and reinstalling
or download a app like freepdf
let me know, cause the solution depends on what software you are using.
Aug 21, 2009 | HP Photosmart D7460 Printer
What is print to file? What is output file name?
It is windows way of storing a document for printing later.
It will save the job you want to print at another time but ask you for a file name so that you can give it a name you will remember.
It will do this if it is set as the DEFAULT printer.
To change that and provided you have a printer installed then go to CONTROL PANEL / printers and faxes / then right click on the printer you want as the default and on the box that opens will be that exact option, click it and you are done. it wont ask you those questions again.
If this information was useful please click below
Aug 19, 2009 | Konica Minolta magicolor 2550 EN Laser...
Can't print a pdf file
Sounds like you are using the PDF printer as your selected printer - this is for creating PDF files in which case you would give it a name.
If you have a PDF file open, simply select your printer (1610) as the printer to print to as with any other documents you print.
Dec 29, 2008 | HP PSC 1610v All-in-One Printer
Does not print. Asks for output file instead.
The default printer is set to be "file". Here's what you must do:
- Go to printers dialogue box and right click on your printer name and selectd "Set s default printer"
 - Right click on printers name and chose Properties. then look for a check box saing something like "print to file" and unchek it.
This sould resolve the problem.
Best regards
Nov 12, 2008 | HP DeskJet F380 All-In-One Printer
Its keeps asking for my output file name when i go to print.what is a output file name ?
Sounds like whatever your printing to is set for print to file or your default printer has changed.
Go into the control panel, select printers, select the printer that you want to use and press the right mouse buttons for properties.
Select the ports tab and make sure that the file box isn't checked and that the USB port is (or whatever port your printing with).
Press ok
Make sure that you printer is set for default printer.
Jun 10, 2008 | Office Equipment & Supplies
Lexmark z 600
when i push to print it says output file name what is that?
Nov 14, 2007 | Lexmark Z600 InkJet Printer
Brother QL-500 Thermal Label Printer Logo
73 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
